[petsc-dev] PETSc-3.10.4 with Python3
Antonio Trande
anto.trande at gmail.com
Tue Mar 12 12:58:05 CDT 2019
I prefer wait for PETSc-3.11
Thanks a lot.
On 12/03/19 18:11, Balay, Satish wrote:
> BTW: you could just try out the changes from jed/python3-futurize -
> and see if that is sufficient for the fedora build of petsc-3.10
> [when we tested that branch - it worked for our common use cases]
> Satish
> On Tue, 12 Mar 2019, Balay, Satish via petsc-dev wrote:
>> petsc-3.11 - likely to be released by the end of the month, will work with python3
>> Wrt PETSc-3.10 the feature is in branch jed/python3-futurize (which is
>> off 3.10 - so it can be cleanly merged to 3.10) - but then - some
>> fixes were added later (so will have to identify them and back-port - not
>> sure if that is worth the effort)
>> Satish
>> On Tue, 12 Mar 2019, Antonio Trande via petsc-dev wrote:
>>> Hi all.
>>> Does exist a patch for compiling PETSc-3.10.4 with Python3?
Antonio Trande
Fedora Project
mailto 'sagitter at fedoraproject dot org'
GPG key: 0x6e0331dd1699e4d7
GPG key server: https://keys.fedoraproject.org/
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190312/4e2568fa/attachment.sig>
