[petsc-dev] PETSc-3.10.4 with Python3
    Balay, Satish
    balay at mcs.anl.gov
    Tue Mar 12 12:11:32 CDT 2019
BTW: you could just try out the changes from jed/python3-futurize -
and see if that is sufficient for the fedora build of petsc-3.10
[when we tested that branch - it worked for our common use cases]
Satish
On Tue, 12 Mar 2019, Balay, Satish via petsc-dev wrote:
> petsc-3.11 - likely to be released by the end of the month, will work with python3
> Wrt PETSc-3.10 the feature is in branch jed/python3-futurize (which is
> off 3.10 - so it can be cleanly merged to 3.10) - but then - some
> fixes were added later (so will have to identify them and back-port - not
> sure if that is worth the effort)
> Satish
> On Tue, 12 Mar 2019, Antonio Trande via petsc-dev wrote:
> > Hi all.
> > Does exist a patch for compiling PETSc-3.10.4 with Python3?
