[petsc-dev] Unused macros in petscconf.h
Jed Brown
jed at jedbrown.org
Sat Jun 29 08:39:58 CDT 2019
Matthew Knepley <knepley at gmail.com> writes:
>> > On Fri, Jun 28, 2019 at 2:04 PM Smith, Barry F. via petsc-dev <
>> > petsc-dev at mcs.anl.gov> wrote:
>> >> You are right, these do not belong in petscconf.h
>> > The problematic thing here is hiding information from users of
>> > PETSc. If you are a user that counts on PETSc configure to check
>> > something, but then we hide it because we do not use it, I would not
>> > be happy.
>> You want PETSc to test things that it doesn't use because maybe a user
>> would want to know? Where does that end
> Very clearly it ends with testing the things users SPECIFICALLY ASKED
> US TO TEST on the configure command line.
They asked us to test the size of short and for the existence of sched.h
and mkstemp?
>> and how would we ever know if
>> the information is correct?
> This is just nonsensical. We know its correct because we tested it.
Only by the code that decides whether to define the macro, but if one of
those tests is/becomes broken (this has happened), we wouldn't know.
