[petsc-dev] Unused macros in petscconf.h
    Matthew Knepley
    knepley at gmail.com
    Sat Jun 29 05:48:13 CDT 2019
On Fri, Jun 28, 2019 at 4:37 PM Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> > On Fri, Jun 28, 2019 at 2:04 PM Smith, Barry F. via petsc-dev <
> > petsc-dev at mcs.anl.gov> wrote:
> >>   You are right, these do not belong in petscconf.h
> > The problematic thing here is hiding information from users of
> > PETSc. If you are a user that counts on PETSc configure to check
> > something, but then we hide it because we do not use it, I would not
> > be happy.
> You want PETSc to test things that it doesn't use because maybe a user
> would want to know?  Where does that end
Very clearly it ends with testing the things users SPECIFICALLY ASKED US TO
TEST
on the configure command line.
> and how would we ever know if
> the information is correct?
This is just nonsensical. We know its correct because we tested it.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190629/8ef16510/attachment.html>
