[petsc-dev] PETSc blame digest (next) 2019-06-20
    Hapla  Vaclav
    vaclav.hapla at erdw.ethz.ch
    Thu Jun 20 09:01:31 CDT 2019
> On 20 Jun 2019, at 15:56, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch> wrote:
>> On 20 Jun 2019, at 15:52, Vaclav Hapla <vaclav.hapla at erdw.ethz.ch> wrote:
>>> On 20 Jun 2019, at 15:15, Hapla Vaclav <vaclav.hapla at erdw.ethz.ch> wrote:
>>>> On 20 Jun 2019, at 15:14, Jed Brown <jed at jedbrown.org> wrote:
>>>> Hapla  Vaclav via petsc-dev <petsc-dev at mcs.anl.gov> writes:
>>>>>> On 20 Jun 2019, at 14:28, PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov> wrote:
>>>>>> Dear PETSc developer,
>>>>>> This email contains listings of contributions attributed to you by
>>>>>> `git blame` that caused compiler errors or warnings in PETSc automated
>>>>>> testing.  Follow the links to see the full log files. Please attempt to fix
>>>>>> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
>>>>>> to resolve the issues.
>>>>>> Thanks,
>>>>>> The PETSc development team
>>>>>> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/eb91f32
>>>>>> MatLoad_Dense_HDF5 impl.
>>>>>> src/mat/impls/dense/seq/densehdf5.c:62
>>>>>> [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs//archive/2019/06/20/build_next_arch-linux-pkgs-cxx-mlib_el6.log]
>>>>>>  /home/sandbox/petsc/petsc.next-3/src/mat/impls/dense/seq/densehdf5.c:62: undefined reference to `PetscViewerHDF5Load'
>>>>> Does it mean I need to change visibility of PetscViewerHDF5Load in isimpl.h to PETSC_EXTERN?
>>>>> Are you OK with that?
>>>> Yes, and when doing that, it needs a Developer level man page.
>>> OK, thanks.
>> So as a rule of thumb, every PETSC_EXTERN function should be documented, although in private headers?
>> Then src/vec/is/utils/hdf5io.c should have
>> #include <petsc/private/isimpl.h> /*I "petsc/private/isimpl.h" I*/
>> Looks a bit weird, doesn't it?
>> I think there are countless cases petsc-wide which break this.
> dev manual page 15 bullet 15:
> "private functions may need to be marked PETSC_EXTERN"
> There is an example of MatHeaderReplace. It hasn't a manpage.
Well, I'm not against making it public (it originally was) and write a manpage, but then it should be also moved to the public header file.
Sorry for sending a few previous emails only to Jed.
Vaclav
