[petsc-dev] error in Jenkins but not nightly
Jed Brown
jed at jedbrown.org
Mon Jun 10 14:15:51 CDT 2019
"Smith, Barry F. via petsc-dev" <petsc-dev at mcs.anl.gov> writes:
> Yes. If the testing system were smart enough we could have the tests actually update the "prebuilt" automatically when things change. This would be more scalable in human efficiency. In addition when setting up a new test machine no need to manually make the prebuilts, the testing will just build them the first time it is run.
> Each examples/arch-* would have a variable listing the packages it uses that it wishes to be prebuilt. Each examples/arch-* would have list a dir for keeping its prebuilts. This could possibly be in the petsc directory. The script would check for any missing prebuilt, then build them with --prefix. It would then check using the version in the package.py and the version of the prebuilt (how to get that info easily?) and rebuild any packages that need updating with --prefix. Easy Peasy. Then run the regular tests.
An alternative would be to spack install those dependencies since it
handles caching and upgrades more reliably.
