[petsc-dev] Fwd: [mumps-users] MUMPS MPI (5.2.1) does not compile
    Balay, Satish
    balay at mcs.anl.gov
    Tue Jul 23 09:58:26 CDT 2019
Ok - I think the current issue is about MUMPS building shared
libraries. Current mumps release lacks this feature.
And these patches enable building mumps as shared library - but the
patch is linux specific - and not portable.
It would be great if this can be made portable.
Currently when mumps is built via petsc using --download-mumps - its
build as static - but with -fPIC [or equivalent] - so it gets sucked
into libpetsc.so. [the same with scalapack].
Satish
On Mon, 22 Jul 2019, Antonio Trande via petsc-dev wrote:
> On 22/07/19 20:28, Pierre Jolivet via petsc-dev wrote:
> > We are having trouble compiling git.mumps with similar errors (using
> > ifort 2017, yikes).
> > Could the forwarded patches be applied to petsc/pkg-mumps, please?
> > Thanks in advance (and sorry if this should be handled @petsc-maint),
> > Pierre
> I have just used 1 Make job (make -j1) to complete the compilation.
> Anyway, MUMPS-5.2.1 has been just now pushed on Fedora repositories and
> compiled fine on Fedora 31 (and CentOS7):
> https://src.fedoraproject.org/rpms/MUMPS/tree/master
