[petsc-dev] Configure issue, PETSC_USE_SOCKET_VIEWER not defined
Jose E. Roman
jroman at dsic.upv.es
Thu Jul 18 09:00:50 CDT 2019
My recent PR#1886 is also related to what Lisandro reports:
https://bitbucket.org/petsc/petsc/pull-requests/1886/fix-compiler-warning/diff
The corresponding configure.log is here:
http://slepc.upv.es/buildbot/builders/athor-linux-icc-c-complex-int64-mkl/builds/534/steps/Configure%20PETSc/logs/configure.log
Jose
> El 18 jul 2019, a las 15:07, Smith, Barry F. via petsc-dev <petsc-dev at mcs.anl.gov> escribió:
> Lisandro,
> Thanks for letting us know. Could you please send configure.log for your failed case. The code to detect and use the variable is still in the PETSc source so I must have introduced something that makes it no longer function correctly. As soon as I can after getting your configure.log I'll debug and fix.
> Barry
>> On Jul 18, 2019, at 5:21 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
>> PETSC_USE_SOCKET_VIEWER is no longer defined in petsconf.h when configuring on my Fedora 30.
>> I think the problem started in the following commit, the parent of this one seems to be OK.
>> commit 2475b7ca256cea2a4b7cbf2d8babcda14e5fa36e
>> Author: Barry Smith <bsmith at mcs.anl.gov>
>> Date: Sun Jun 30 02:41:52 2019 -0500
>> Remove testing and inserting into petscconf.h items that are not actually used by PETSc
>> 1) PETSC_HAVE_LIBXXXX - which was rarely used
>> be careful with the package libpng and libjpeg since they have lib in the name of the package
>> 2) various system include files that are never used or always exist: for example stdlib.h
>> 3) various system functions that are never used or always exist
>> 4) fixes for requires for MUMPS and SuperLU_DIST when dependent packages are installed or not installed (unrelated to the rest of this pull request)
>> 5) packages that always exist such as PETSC_HAVE_BLASLAPACK, or are not used by PETSc such as PETSC_HAVE_NETCFD
>> 6) remove a couple of uses of HAVE_LIB* in the code that were not needed by adjusting the configure code slightly
>> 7) remove all the #if guards for each entry in petscconf.h since petscconf.h already has a guard and
>> the values are never defined else where the extra guards just make the file cluttered
>> For a build with about 10 external packages this reduced the size of petscconf.h from 1236 lines to 828/4 around 220 entries.
>> Commit-type: style-fix, cleanup
>> Reported-by: Jed Brown <jed at jedbrown.org
>> Lisandro Dalcin
>> Research Scientist
>> Extreme Computing Research Center (ECRC)
>> King Abdullah University of Science and Technology (KAUST)
>> http://ecrc.kaust.edu.sa/
