[petsc-dev] Configure issue, PETSC_USE_SOCKET_VIEWER not defined
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Thu Jul 18 08:07:37 CDT 2019
  Lisandro,
    Thanks for letting us know. Could you please send configure.log for your failed case. The code to detect and use the variable is still in the PETSc source so I must have introduced something that makes it no longer function correctly. As soon as I can after getting your configure.log I'll debug and fix.
   Barry
> On Jul 18, 2019, at 5:21 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> PETSC_USE_SOCKET_VIEWER is no longer defined in petsconf.h when configuring on my Fedora 30.
> I think the problem started in the following commit, the parent of this one seems to be OK.
> commit 2475b7ca256cea2a4b7cbf2d8babcda14e5fa36e
> Author: Barry Smith <bsmith at mcs.anl.gov>
> Date:   Sun Jun 30 02:41:52 2019 -0500
>     Remove testing and inserting into petscconf.h items that are not actually used by PETSc
>     1) PETSC_HAVE_LIBXXXX - which was rarely used
>        be careful with the package libpng and libjpeg since they have lib in the name of the package
>     2) various system include files that are never used or always exist: for example stdlib.h
>     3) various system functions that are never used or always exist
>     4) fixes for requires for MUMPS and SuperLU_DIST when dependent packages are installed or not installed (unrelated to the rest of this pull request)
>     5) packages that always exist such as PETSC_HAVE_BLASLAPACK, or are not used by PETSc such as PETSC_HAVE_NETCFD
>     6) remove a couple of uses of HAVE_LIB* in the code that were not needed by adjusting the configure code slightly
>     7) remove all the #if guards for each entry in petscconf.h since petscconf.h already has a guard and
>        the values are never defined else where the extra guards just make the file cluttered
>     For a build with about 10 external packages this reduced the size of petscconf.h from 1236 lines to 828/4 around 220 entries.
>     Commit-type: style-fix, cleanup
>     Reported-by: Jed Brown <jed at jedbrown.org
> Lisandro Dalcin
> Research Scientist
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
