[petsc-dev] Fwd: [petsc-maint] Looking for PETSc MatCreateMPIBAIJ routine
    Matthew Knepley
    knepley at gmail.com
    Thu Jan 24 05:17:38 CST 2019
The timewarp that is NASA is using PETSc from before Maria was born.
   Matt
---------- Forwarded message ---------
From: Michael Robinson via petsc-maint <petsc-maint at mcs.anl.gov>
Date: Wed, Jan 23, 2019 at 2:37 PM
Subject: [petsc-maint] Looking for PETSc MatCreateMPIBAIJ routine
To: petsc-maint at mcs.anl.gov <petsc-maint at mcs.anl.gov>
PETSc Team:
I am trying to compile and link the NASA DPLR code (a Fortran CFD code)
with PETSc v3.2.7 on the SGI ICE XA at HPC’s ARL center.  I downloaded
and compiled v3.2.7 with no problems.  At link time, I get a lot of
undefined references to X routines, e.g. XDrawLine called from several
different PETSc routines.  I don’t want to use any X routines and I
don’t think X is even installed on this machine.
How do I configure or tell PETSc to not invoke these X routines.  I
just want numerics, no drawing/plotting/windowing etc.  Thanks!
Michael A. Robinson, Ph.D.            michael.robinson at kratosdefense.com
CFD Research Scientist                           256-327-8139  (Voice)
Kratos Defense & Rocket Support Services         256-327-8120  (Fax)
4904 Research Drive
Huntsville, AL  35805
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190124/9149ec5d/attachment.html>
