[petsc-dev] How to add root values to leaves in PetscSF?
Zhang, Junchao
jczhang at mcs.anl.gov
Tue Jan 22 17:21:48 CST 2019
On Tue, Jan 22, 2019 at 5:07 PM Jed Brown <jed at jedbrown.org<mailto:jed at jedbrown.org>> wrote:
"Zhang, Junchao" <jczhang at mcs.anl.gov<mailto:jczhang at mcs.anl.gov>> writes:
> On Tue, Jan 22, 2019 at 4:08 PM Jed Brown <jed at jedbrown.org<mailto:jed at jedbrown.org><mailto:jed at jedbrown.org<mailto:jed at jedbrown.org>>> wrote:
>> It is not supported at this time. What does your use case look like?
>> Do roots have degree greater than 1?
> Yes. Imagine a vecscatter x[0]->y[0], x[1]->y[0], x[1]->y[1],x[2]->y[1]. I build an SF for SCATTER_FORWARD. Now I wan to do SCATTER_REVERSE with ADD_VALUES.
> To solve this problem without creating another SF and without breaking current SF API, I propose to add PetscSFBcastAndOp(sf, unit, rootdata, leafdata, op)
Is this pattern needed for some algorithm or application or is this
about implementing the full VecScatter interface (modulo ill-defined
operations) in terms of SF? If the former, I'd like to understand it.
If the latter, I'm okay with you extending the interface as proposed.
It is the latter.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190122/f71b6837/attachment.html>
