[petsc-dev] Man pages usage of "Collective on XXX"
Matthew Knepley
knepley at gmail.com
Wed Feb 6 14:08:30 CST 2019
On Wed, Feb 6, 2019 at 3:03 PM Dave May via petsc-dev <petsc-dev at mcs.anl.gov>
wrote:
> * I notice that most man pages will say
> Collective on <type>
> e.g.
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMDA/DMDACreate.html
> * Some others say
> Collective on <implementation-name>
> e.g.
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMDA/DMDACreateNaturalVector.html
> or
> https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMCompositeAddDM.html
> In the former, at least the word "DMDA" gets linked back to the
> implementation, whilst in the latter "DMComposite" does not.
> Should "Collective on <implementation-name>" be avoided?
> It is potentially somewhat unclear given that the name of the
> implementation does not appear anywhere in the arg list (type or variable
> name).
> That said, "collective on <type>" could be similarly criticized if a
> method existed with two args of the same type.
> * Many of the methods in this file
> www.mcs.anl.gov/petsc/petsc-current/src/dm/impls/shell/dmshell.c.html
> simply say "Collective" (without a type or implementation name), or they
> say "Logically Collective on XXX"
> I do realize that there is a pattern that the statement "collective on
> xxx" or "not collective" applies (implicitly) to the first argument of any
> PETSc function call (at least that I've come across) so possibly just
> indicating the method as "Collective" might suffice (assuming (i) there is
> a pattern and (ii) everyone knows about the pattern).
> Q: Should I make a PR to unify these man pages (and any others I spot) to
> just say "Collective on <type>"?
This has always bugged me. It should say, I think, 'Collective on <arg
name>", or "Logically collective on <arg name>".
Matt
> Thanks,
> Dave
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190206/70c82ad6/attachment.html>
