[petsc-dev] Man pages usage of "Collective on XXX"
    Dave May
    dave.mayhem23 at gmail.com
    Wed Feb  6 14:01:57 CST 2019
* I notice that most man pages will say
  Collective on <type>
e.g.
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMDA/DMDACreate.html
* Some others say
  Collective on <implementation-name>
e.g.
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DMDA/DMDACreateNaturalVector.html
or
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/DM/DMCompositeAddDM.html
In the former, at least the word "DMDA" gets linked back to the
implementation, whilst in the latter "DMComposite" does not.
Should "Collective on <implementation-name>" be avoided?
It is potentially somewhat unclear given that the name of the
implementation does not appear anywhere in the arg  list (type or variable
name).
That said, "collective on <type>" could be similarly criticized if a method
existed with two args of the same type.
* Many of the methods in this file
  www.mcs.anl.gov/petsc/petsc-current/src/dm/impls/shell/dmshell.c.html
simply say "Collective" (without a type or implementation name), or they
say "Logically Collective on XXX"
I do realize that there is a pattern that the statement "collective on xxx"
or "not collective" applies (implicitly) to the first argument of any PETSc
function call (at least that I've come across) so possibly just indicating
the method as "Collective" might suffice (assuming (i) there is a pattern
and (ii) everyone knows about the pattern).
Q: Should I make a PR to unify these man pages (and any others I spot) to
just say "Collective on <type>"?
  Dave
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190206/a5462462/attachment.html>
