[petsc-dev] is DMSetDS not in master?
    Mark Adams
    mfadams at lbl.gov
    Fri Feb  1 10:00:04 CST 2019
OK, it's not in Changes and there is one comment to it.
On Fri, Feb 1, 2019 at 10:50 AM Matthew Knepley <knepley at gmail.com> wrote:
> I removed it, since no one should use it anymore. You use
> DMSetField()+DMCreateDS() instead.
>   THanks,
>     Matt
> On Fri, Feb 1, 2019 at 10:38 AM Mark Adams via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
>> 10:37 master= ~/Codes/petsc$ git grep DMSetDS
>> src/dm/interface/dm.c:.seealso: DMGetDS(), DMSetDS()
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190201/1be2c916/attachment.html>
