[petsc-dev] is DMSetDS not in master?
    Matthew Knepley
    knepley at gmail.com
    Fri Feb  1 09:50:33 CST 2019
I removed it, since no one should use it anymore. You use
DMSetField()+DMCreateDS() instead.
  THanks,
    Matt
On Fri, Feb 1, 2019 at 10:38 AM Mark Adams via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> 10:37 master= ~/Codes/petsc$ git grep DMSetDS
> src/dm/interface/dm.c:.seealso: DMGetDS(), DMSetDS()
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190201/12314138/attachment.html>
