[petsc-dev] IMPORTANT PETSc repository changed from Bucketbit to GitLab
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Tue Aug 20 19:05:25 CDT 2019
  Is it so difficult for you to change the link in your test system to petsc-pre-gitlab?
  Barry
> On Aug 20, 2019, at 4:40 PM, Fande Kong via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> Any way to have the link https://bitbucket.org/petsc/petsc valid (read only) for a couple of weeks?  We have some tests that dynamically picks up a particular version of PETSc (master, maint, tag).  The link was removed now,  and that disabled us to have daily tests. If we could keep this link for a couple of weeks, that will give me a grace period to update all the impacted tests.
> Any particular reason that we have to rename petsc to petsc-pre-gitlab?
> Thanks,
> Fande Kong,
> On Tue, Aug 20, 2019 at 2:52 AM Lisandro Dalcin via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> Dear Satish, are you planning to migrate petsc4py?
> On Mon, 19 Aug 2019 at 23:47, Balay, Satish via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> A note:
> The bitbucket repository is saved at https://bitbucket.org/petsc/petsc-pre-gitlab
> The git part is now read-only. The other parts [issues, PRs, wiki etc] are perhaps writable - but we should avoid that.
> Satish
> On Mon, 19 Aug 2019, Smith, Barry F. via petsc-dev wrote:
> >    PETSc folks.
> >     This announcement is for people who access PETSc from the BitBucket repository or post issues or have other activities with the Bitbucket repository
> >    We have changed  the location of the PETSc repository from BitBucket to GitLab. For each copy of the repository you need to do
> >    git remote set-url origin git at gitlab.com<mailto:git at gitlab.com>:petsc/petsc.git
> >    or
> >    git remote set-url origin https://gitlab.com/petsc/petsc.git
> >    You will likely also want to set up an account on gitlab and remember to set the ssh key information
> >    if you previously had write permission to the petsc repository and cannot write to the new repository please email bsmith at mcs.anl.gov<mailto:bsmith at mcs.anl.gov> with your GitLab
> >    username and the email used
> >     Please do not make pull requests to the Gitlab site yet; we will be manually processing the PR from the BitBucket site over the next couple of
> >     days as we implement the testing.
> >     Please be patient, this is all new to use and it may take a few days to get out all the glitches.
> >     Thanks for your support
> >     Barry
> >    The reason for switching to GitLab is that it has a better testing system than BitBucket and Gitlab. We hope that will allow us to test and manage
> >    pull requests more rapidly, efficiently and accurately, thus allowing us to improve and add to PETSc more quickly.
> Lisandro Dalcin
> Research Scientist
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
