[petsc-dev] IMPORTANT PETSc repository changed from Bucketbit to GitLab
    Fande Kong
    fdkong.jd at gmail.com
    Tue Aug 20 16:40:36 CDT 2019
Any way to have the link https://bitbucket.org/petsc/petsc valid (read
only) for a couple of weeks?  We have some tests that dynamically picks up
a particular version of PETSc (master, maint, tag).  The link was removed
now,  and that disabled us to have daily tests. If we could keep this link
for a couple of weeks, that will give me a grace period to update all the
impacted tests.
Any particular reason that we have to rename petsc to petsc-pre-gitlab?
Fande Kong,
On Tue, Aug 20, 2019 at 2:52 AM Lisandro Dalcin via petsc-dev <
petsc-dev at mcs.anl.gov> wrote:
> Dear Satish, are you planning to migrate petsc4py?
> On Mon, 19 Aug 2019 at 23:47, Balay, Satish via petsc-dev <
>> A note:
>> The bitbucket repository is saved at
>> https://bitbucket.org/petsc/petsc-pre-gitlab
>> The git part is now read-only. The other parts [issues, PRs, wiki etc]
>> are perhaps writable - but we should avoid that.
>> Satish
>> On Mon, 19 Aug 2019, Smith, Barry F. via petsc-dev wrote:
>> >    PETSc folks.
>> >     This announcement is for people who access PETSc from the BitBucket
>> repository or post issues or have other activities with the Bitbucket
>> repository
>> >    We have changed  the location of the PETSc repository from BitBucket
>> to GitLab. For each copy of the repository you need to do
>> >    git remote set-url origin git at gitlab.com<mailto:git at gitlab.com
>> >:petsc/petsc.git
>> >    or
>> >    git remote set-url origin https://gitlab.com/petsc/petsc.git
>> >    You will likely also want to set up an account on gitlab and
>> remember to set the ssh key information
>> >    if you previously had write permission to the petsc repository and
>> cannot write to the new repository please email bsmith at mcs.anl.gov
>> <mailto:bsmith at mcs.anl.gov> with your GitLab
>> >    username and the email used
>> >     Please do not make pull requests to the Gitlab site yet; we will be
>> manually processing the PR from the BitBucket site over the next couple of
>> >     days as we implement the testing.
>> >     Please be patient, this is all new to use and it may take a few
>> days to get out all the glitches.
>> >     Thanks for your support
>> >     Barry
>> >    The reason for switching to GitLab is that it has a better testing
>> system than BitBucket and Gitlab. We hope that will allow us to test and
>> manage
>> >    pull requests more rapidly, efficiently and accurately, thus
>> allowing us to improve and add to PETSc more quickly.
> Lisandro Dalcin
> Research Scientist
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190820/2814de91/attachment.html>
