[petsc-dev] hypre and CUDA
    Mark Adams
    mfadams at lbl.gov
    Fri Aug 16 10:09:43 CDT 2019
Thanks Karl,
>From what Barry said, the hypre configure has not done the CUDA stuff so it
can't work right now.
On Thu, Aug 15, 2019 at 8:57 PM Karl Rupp <rupp at iue.tuwien.ac.at> wrote:
> Hi,
> one way to test is to run a sequential example through nv-prof:
>   $> nvprof ./ex56 ...
> https://devblogs.nvidia.com/cuda-pro-tip-nvprof-your-handy-universal-gpu-profiler/
> If it uses the GPU, then you will get some information on the GPU
> kernels called. If it doesn't use the GPU, the list will be (almost) empty.
> Best regards,
> Karli
> On 8/15/19 5:47 PM, Mark Adams via petsc-dev wrote:
> > I have configured with Hypre on SUMMIT, with cuda, and it ran. I'm now
> > trying to verify that it used GPUs (I doubt it). Any ideas on how to
> > verify this? Should I use the cuda vecs and mats, or does Hypre not
> > care. Can I tell hypre not to use GPUs other than configuring an
> > non-cude PETSc? I'm not sure how to run a job without GPUs, but I will
> > look into it.
> > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190816/3374c58b/attachment.html>
