[petsc-dev] [petsc-maint] running CUDA on SUMMIT
    Mark Adams
    mfadams at lbl.gov
    Wed Aug 14 19:44:56 CDT 2019
OK, I'll run single. It a bit perverse to run with 4 byte floats and 8 byte
integers ... I could use 32 bit ints and just not scale out.
On Wed, Aug 14, 2019 at 6:48 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>  Mark,
>    Oh, I don't even care if it converges, just put in a fixed number of
> iterations. The idea is to just get a baseline of the possible improvement.
>     ECP is literally dropping millions into research on "multi precision"
> computations on GPUs, we need to have some actual numbers for the best
> potential benefit to determine how much we invest in further investigating
> it, or not.
>     I am not expressing any opinions on the approach, we are just in the
> fact gathering stage.
>    Barry
> > On Aug 14, 2019, at 2:27 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > On Wed, Aug 14, 2019 at 2:35 PM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> >   Mark,
> >    Would you be able to make one run using single precision? Just single
> everywhere since that is all we support currently?
> > Experience in engineering at least is single does not work for FE
> elasticity. I have tried it many years ago and have heard this from others.
> This problem is pretty simple other than using Q2. I suppose I could try
> it, but just be aware the FE people might say that single sucks.
> >    The results will give us motivation (or anti-motivation) to have
> support for running KSP (or PC (or Mat)  in single precision while the
> simulation is double.
> >    Thanks.
> >      Barry
> > For example if the GPU speed on KSP is a factor of 3 over the double on
> GPUs this is serious motivation.
> > > On Aug 14, 2019, at 12:45 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > > FYI, Here is some scaling data of GAMG on SUMMIT. Getting about 4x GPU
> speedup with 98K dof/proc (3D Q2 elasticity).
> > > This is weak scaling of a solve. There is growth in iteration count
> folded in here. I should put rtol in the title and/or run a fixed number of
> iterations and make it clear in the title.
> > > Comments welcome.
> <out_cpu_012288><out_cpu_001536><out_cuda_012288><out_cpu_000024><out_cpu_000192><out_cuda_001536><out_cuda_000192><out_cuda_000024><weak_scaling_cpu.png><weak_scaling_cuda.png>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190814/80ead9c8/attachment.html>
