[petsc-dev] [petsc-maint] running CUDA on SUMMIT
Mark Adams
mfadams at lbl.gov
Wed Aug 14 15:46:41 CDT 2019
On Wed, Aug 14, 2019 at 2:19 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> Mark,
> This is great, we can study these for months.
> 1) At the top of the plots you say SNES but that can't be right, there is
> no way it is getting such speed ups for the entire SNES solve since the
> Jacobians are CPUs and take much of the time. Do you mean the KSP part of
> the SNES solve?
It uses KSPONLY. And solve times are KSPSolve with KSPSetUp called before.
> 2) For the case of a bit more than 1000 processes the speedup with GPUs is
> fantastic, more than 6?
I did not see that one, but it is plausible and there is some noise in this
data. The largest solve had a speedup of about 4x.
> 3) People will ask about runs using all 48 CPUs, since they are there it
> is a little unfair to only compare 24 CPUs with the GPUs. Presumably due to
> memory bandwidth limits 48 won't be much better than 24 but you need it in
> your back pocket for completeness.
Ah, good point. I just cut and paste but I should run a little test and see
where it saturates.
> 4) From the table
> KSPSolve 1 1.0 5.4191e-02 1.0 9.35e+06 7.3 1.3e+04 5.6e+02
> 8.3e+01 0 0 4 0 3 10 57 97 52 81 1911 3494 114 3.06e-01 129
> 1.38e-01 84
> PCApply 17 1.0 4.5053e-02 1.0 9.22e+06 8.5 1.1e+04 5.6e+02
> 3.4e+01 0 0 3 0 1 8 49 81 44 33 1968 4007 98 2.58e-01 113
> 1.19e-01 81
> only 84 percent of the total flops in the KSPSolve are on the GPU and only
> 81 for the PCApply() where are the rest? MatMult() etc are doing 100
> percent on the GPU, MatSolve on the coarsest level should be tiny and not
> taking 19 percent of the flops?
That is the smallest test with 3465 equations on 24 cores. the R and P and
coarse grid are on the CPU. Look at larger tests.
> Thanks
> Barry
> > On Aug 14, 2019, at 12:45 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > FYI, Here is some scaling data of GAMG on SUMMIT. Getting about 4x GPU
> speedup with 98K dof/proc (3D Q2 elasticity).
> > This is weak scaling of a solve. There is growth in iteration count
> folded in here. I should put rtol in the title and/or run a fixed number of
> iterations and make it clear in the title.
> > Comments welcome.
> <out_cpu_012288><out_cpu_001536><out_cuda_012288><out_cpu_000024><out_cpu_000192><out_cuda_001536><out_cuda_000192><out_cuda_000024><weak_scaling_cpu.png><weak_scaling_cuda.png>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190814/2d90bb81/attachment-0001.html>
