[petsc-dev] [petsc-maint] running CUDA on SUMMIT
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Wed Aug 14 13:35:05 CDT 2019
  Mark,
   Would you be able to make one run using single precision? Just single everywhere since that is all we support currently?
   The results will give us motivation (or anti-motivation) to have support for running KSP (or PC (or Mat)  in single precision while the simulation is double.
   Thanks.
     Barry
For example if the GPU speed on KSP is a factor of 3 over the double on GPUs this is serious motivation.
> On Aug 14, 2019, at 12:45 PM, Mark Adams <mfadams at lbl.gov> wrote:
> FYI, Here is some scaling data of GAMG on SUMMIT. Getting about 4x GPU speedup with 98K dof/proc (3D Q2 elasticity).
> This is weak scaling of a solve. There is growth in iteration count folded in here. I should put rtol in the title and/or run a fixed number of iterations and make it clear in the title.
> Comments welcome.
> <out_cpu_012288><out_cpu_001536><out_cuda_012288><out_cpu_000024><out_cpu_000192><out_cuda_001536><out_cuda_000192><out_cuda_000024><weak_scaling_cpu.png><weak_scaling_cuda.png>
