[petsc-dev] [petsc-maint] running CUDA on SUMMIT
    Mark Adams
    mfadams at lbl.gov
    Wed Aug 14 12:45:21 CDT 2019
FYI, Here is some scaling data of GAMG on SUMMIT. Getting about 4x GPU
speedup with 98K dof/proc (3D Q2 elasticity).
This is weak scaling of a solve. There is growth in iteration count folded
in here. I should put rtol in the title and/or run a fixed number of
iterations and make it clear in the title.
Comments welcome.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190814/8ff3695e/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190814/8ff3695e/attachment-0008.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190814/8ff3695e/attachment-0009.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190814/8ff3695e/attachment-0010.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190814/8ff3695e/attachment-0011.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190814/8ff3695e/attachment-0012.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190814/8ff3695e/attachment-0013.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190814/8ff3695e/attachment-0014.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190814/8ff3695e/attachment-0015.obj>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190814/8ff3695e/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190814/8ff3695e/attachment-0003.png>
