[petsc-dev] Is master broken?
    Karl Rupp
    rupp at iue.tuwien.ac.at
    Sat Aug  3 22:03:30 CDT 2019
Hi Mark,
it's fine if you just double-check that all your fixes are in master
when you're back :-)
Best regards and enjoy your vacation,
Karli
On 8/3/19 8:47 PM, Mark Adams wrote:
> Karl,
> Did you want me to do anything at this point? (on vacation this week) I
> will verify that master is all fixed if you get all my stuff integrated
> when I get back to work in a week.
> Thanks,
> Mark
> On Sat, Aug 3, 2019 at 10:50 AM Karl Rupp <rupp at iue.tuwien.ac.at
> <mailto:rupp at iue.tuwien.ac.at>> wrote:
>     If you ignore the initial ViennaCL-related commits and check against
>     current master (that just received cherry-picked updates from your PR),
>     then there are really only a few commits left that are not yet
>     integrated.
>     (I'll extract two more PRs on Monday, so master will soon have your
>     fixes in.)
>     Best regards,
>     Karli
>     On 8/3/19 5:21 AM, Balay, Satish wrote:
>      > I've attempted to rebase this branch over latest master - and pushed
>      > my changes to branch mark/gamg-fix-viennacl-rebased-v2
>      > You might want to check each of your commits in this branch to see if
>      > they are ok. I had to add one extra commit - to make it match 'merge
>      > of mark/gamg-fix-viennacl-rebased and master'.
>      > This branch has 21 commits. I think its best if you can collapse them
>      > into reasonable chunks of changes. [presumably a single commit
>     for all
>      > the changes is not the correct thing here. But the current set of 21
>      > commits are all over the place]
>      > If you are able to migrate to this branch - its best to delete
>     the old
>      > one [i.e origin/mark/gamg-fix-viennacl-rebased]
>      > Satish
>      > On Fri, 2 Aug 2019, Mark Adams via petsc-dev wrote:
>      >> I have been cherry-picking, etc, branch
>      >> it is very messed up. Can someone please update this branch when
>     all the
>      >> fixes are settled down? eg, I am seeing dozens of modified files
>     that I
>      >> don't know anything about and I certainly don't want to put in a
>     PR for
>      >> them.
>      >> I also seem to lose my pinToCPU method for cuda matrices. I don't
>      >> understand how that conflicted with anyone else but it did.
>      >> Thanks,
>      >> Mark
