[petsc-dev] Is master broken?
    Mark Adams
    mfadams at lbl.gov
    Sat Aug  3 13:47:22 CDT 2019
Karl,
Did you want me to do anything at this point? (on vacation this week) I
will verify that master is all fixed if you get all my stuff integrated
when I get back to work in a week.
On Sat, Aug 3, 2019 at 10:50 AM Karl Rupp <rupp at iue.tuwien.ac.at> wrote:
> If you ignore the initial ViennaCL-related commits and check against
> current master (that just received cherry-picked updates from your PR),
> then there are really only a few commits left that are not yet integrated.
> (I'll extract two more PRs on Monday, so master will soon have your
> fixes in.)
> Best regards,
> Karli
> On 8/3/19 5:21 AM, Balay, Satish wrote:
> > I've attempted to rebase this branch over latest master - and pushed
> > my changes to branch mark/gamg-fix-viennacl-rebased-v2
> > You might want to check each of your commits in this branch to see if
> > they are ok. I had to add one extra commit - to make it match 'merge
> > of mark/gamg-fix-viennacl-rebased and master'.
> > This branch has 21 commits. I think its best if you can collapse them
> > into reasonable chunks of changes. [presumably a single commit for all
> > the changes is not the correct thing here. But the current set of 21
> > commits are all over the place]
> > If you are able to migrate to this branch - its best to delete the old
> > one [i.e origin/mark/gamg-fix-viennacl-rebased]
> > Satish
> > On Fri, 2 Aug 2019, Mark Adams via petsc-dev wrote:
> >> I have been cherry-picking, etc, branch mark/gamg-fix-viennacl-rebased
> and
> >> it is very messed up. Can someone please update this branch when all the
> >> fixes are settled down? eg, I am seeing dozens of modified files that I
> >> don't know anything about and I certainly don't want to put in a PR for
> >> them.
> >> I also seem to lose my pinToCPU method for cuda matrices. I don't
> >> understand how that conflicted with anyone else but it did.
> >> Thanks,
> >> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190803/5db9c2e3/attachment.html>
