[petsc-dev] Is master broken?
    Karl Rupp
    rupp at iue.tuwien.ac.at
    Fri Aug  2 13:23:24 CDT 2019
You should be able to just cherry-pick the commits from Barry's branch
as well as the two other branches.
On 8/2/19 8:13 PM, Mark Adams wrote:
> I picked these two into Barry's branch and it built.
> I would like to get them into my cuda branch. Should I just pick them?
> And not worry about Barry's branch. Or will that not work.
> On Fri, Aug 2, 2019 at 12:03 PM Karl Rupp <rupp at iue.tuwien.ac.at
> <mailto:rupp at iue.tuwien.ac.at>> wrote:
>     FYI: The two branches are currently testing in `next-tmp` and are
>     likely
>     to be merged to master in ~5 hours.
>     Best regards,
>     Karli
>     On 8/2/19 4:53 PM, Smith, Barry F. via petsc-dev wrote:
>      >    Yes, these are bugs in Stefano's work that got into master
>     because we didn't have comprehensive testing. There are two branches
>     in the PR list you can cherry pick that will fix this problem. Sorry
>     about this. We're trying to get them into master as quickly as
>     possible but ....
>      >     Barry
>      >> On Aug 2, 2019, at 8:39 AM, Mark Adams <mfadams at lbl.gov
>     <mailto:mfadams at lbl.gov>> wrote:
>      >> closer,
>      >> On Fri, Aug 2, 2019 at 9:13 AM Smith, Barry F.
>     <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>> wrote:
>      >>    Mark,
>      >>      Thanks, that was not expected to work, I was just verifying
>     the exact cause of the problem and it was what I was guessing.
>      >>      I believe I have fixed it. Please pull that branch again
>     and let me know if it works. If it does we'll do rush testing and
>     get it into master.
>      >>       Thanks
>      >>       Barry
>      >>> On Aug 1, 2019, at 11:08 AM, Mark Adams <mfadams at lbl.gov
>      >>> On Thu, Aug 1, 2019 at 10:30 AM Smith, Barry F.
>      >>>    Send
>      >>> ls arch-linux2-c-debug/include/
>      >>> That is not my arch name. It is something like
>     arch-summit-dbg64-pgi-cuda
>      >>>   arch-linux2-c-debug/include/petscpkg_version.h
>      >>> and configure.log
>      >>>> On Aug 1, 2019, at 5:23 AM, Mark Adams <mfadams at lbl.gov
>      >>>> I get the same error with a fresh clone of master.
>      >>>> On Thu, Aug 1, 2019 at 6:03 AM Mark Adams <mfadams at lbl.gov
>      >>>> Tried again after deleting the arch dirs and still have it.
>      >>>> This is my branch that just merged master. I will try with
>     just master.
>      >>>> Thanks,
>      >>>> On Thu, Aug 1, 2019 at 1:36 AM Smith, Barry F.
>      >>>>    It is generated automatically and put in
>     arch-linux2-c-debug/include/petscpkg_version.h  this include file is
>     included at top of the "bad" source  file crashes so in theory
>     everything is in order check that
>     arch-linux2-c-debug/include/petscpkg_version.h contains
>     PETSC_PKG_CUDA_VERSION_GE and similar macros. If not send configure.lo
>      >>>> check what is in
>     arch-linux2-c-debug/include/petscpkg_version.h it nothing or broken
>     send configure.lo
>      >>>>    Barry
>      >>>>> On Jul 31, 2019, at 9:28 PM, Mark Adams via petsc-dev
>     <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> wrote:
>      >>>>> I am seeing this when I pull master into my branch:
>     "/autofs/nccs-svm1_home1/adams/petsc/src/mat/impls/dense/seq/cuda/densecuda.cu
>     <http://densecuda.cu>"
>      >>>>>            , line 243: error: function call is not allowed in
>     a constant
>      >>>>>            expression
>      >>>>>    #if PETSC_PKG_CUDA_VERSION_GE(10,1,0)
>      >>>>> and I see that this macro does not seem to be defined:
>      >>>>> 22:24 master= ~/Codes/petsc$ git grep PETSC_PKG_CUDA_VERSION_GE
>      >>>>> src/mat/impls/dense/seq/cuda/densecuda.cu:#if
>      >> <make.log><configure.log>
