[petsc-dev] Is master broken?
    Mark Adams
    mfadams at lbl.gov
    Fri Aug  2 13:13:46 CDT 2019
I picked these two into Barry's branch and it built.
I would like to get them into my cuda branch. Should I just pick them? And
not worry about Barry's branch. Or will that not work.
On Fri, Aug 2, 2019 at 12:03 PM Karl Rupp <rupp at iue.tuwien.ac.at> wrote:
> FYI: The two branches are currently testing in `next-tmp` and are likely
> to be merged to master in ~5 hours.
> Best regards,
> Karli
> On 8/2/19 4:53 PM, Smith, Barry F. via petsc-dev wrote:
> >    Yes, these are bugs in Stefano's work that got into master because we
> didn't have comprehensive testing. There are two branches in the PR list
> you can cherry pick that will fix this problem. Sorry about this. We're
> trying to get them into master as quickly as possible but ....
> >     Barry
> >> On Aug 2, 2019, at 8:39 AM, Mark Adams <mfadams at lbl.gov> wrote:
> >> closer,
> >> On Fri, Aug 2, 2019 at 9:13 AM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> >>    Mark,
> >>      Thanks, that was not expected to work, I was just verifying the
> exact cause of the problem and it was what I was guessing.
> >>      I believe I have fixed it. Please pull that branch again and let
> me know if it works. If it does we'll do rush testing and get it into
> master.
> >>       Thanks
> >>       Barry
> >>> On Aug 1, 2019, at 11:08 AM, Mark Adams <mfadams at lbl.gov> wrote:
> >>> On Thu, Aug 1, 2019 at 10:30 AM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> >>>    Send
> >>> ls arch-linux2-c-debug/include/
> >>> That is not my arch name. It is something like
> arch-summit-dbg64-pgi-cuda
> >>>   arch-linux2-c-debug/include/petscpkg_version.h
> >>> and configure.log
> >>>> On Aug 1, 2019, at 5:23 AM, Mark Adams <mfadams at lbl.gov> wrote:
> >>>> I get the same error with a fresh clone of master.
> >>>> On Thu, Aug 1, 2019 at 6:03 AM Mark Adams <mfadams at lbl.gov> wrote:
> >>>> Tried again after deleting the arch dirs and still have it.
> >>>> This is my branch that just merged master. I will try with just
> master.
> >>>> Thanks,
> >>>> On Thu, Aug 1, 2019 at 1:36 AM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> >>>>    It is generated automatically and put in
> arch-linux2-c-debug/include/petscpkg_version.h  this include file is
> included at top of the "bad" source  file crashes so in theory everything
> is in order check that arch-linux2-c-debug/include/petscpkg_version.h
> contains PETSC_PKG_CUDA_VERSION_GE and similar macros. If not send
> configure.lo
> >>>> check what is in arch-linux2-c-debug/include/petscpkg_version.h it
> nothing or broken send configure.lo
> >>>>    Barry
> >>>>> On Jul 31, 2019, at 9:28 PM, Mark Adams via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
> >>>>> I am seeing this when I pull master into my branch:
> >>>>> "/autofs/nccs-svm1_home1/adams/petsc/src/mat/impls/dense/seq/cuda/
> densecuda.cu"
> >>>>>            , line 243: error: function call is not allowed in a
> constant
> >>>>>            expression
> >>>>>    #if PETSC_PKG_CUDA_VERSION_GE(10,1,0)
> >>>>> and I see that this macro does not seem to be defined:
> >>>>> 22:24 master= ~/Codes/petsc$ git grep PETSC_PKG_CUDA_VERSION_GE
> >>>>> src/mat/impls/dense/seq/cuda/densecuda.cu:#if
> >> <make.log><configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190802/2304e1d7/attachment.html>
