[petsc-dev] Is master broken?
    Smith, Barry F.
    bsmith at mcs.anl.gov
    Fri Aug  2 08:13:18 CDT 2019
  Mark,
    Thanks, that was not expected to work, I was just verifying the exact cause of the problem and it was what I was guessing.
    I believe I have fixed it. Please pull that branch again and let me know if it works. If it does we'll do rush testing and get it into master.
     Thanks
     Barry
> On Aug 1, 2019, at 11:08 AM, Mark Adams <mfadams at lbl.gov> wrote:
> On Thu, Aug 1, 2019 at 10:30 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   Send
> ls arch-linux2-c-debug/include/
> That is not my arch name. It is something like arch-summit-dbg64-pgi-cuda
>  arch-linux2-c-debug/include/petscpkg_version.h
> and configure.log
> > On Aug 1, 2019, at 5:23 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > I get the same error with a fresh clone of master.
> > On Thu, Aug 1, 2019 at 6:03 AM Mark Adams <mfadams at lbl.gov> wrote:
> > Tried again after deleting the arch dirs and still have it.
> > This is my branch that just merged master. I will try with just master.
> > Thanks,
> > On Thu, Aug 1, 2019 at 1:36 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> >   It is generated automatically and put in arch-linux2-c-debug/include/petscpkg_version.h  this include file is included at top of the "bad" source  file crashes so in theory everything is in order check that arch-linux2-c-debug/include/petscpkg_version.h contains PETSC_PKG_CUDA_VERSION_GE and similar macros. If not send configure.lo
> > check what is in arch-linux2-c-debug/include/petscpkg_version.h it nothing or broken send configure.lo
> >   Barry
> > > On Jul 31, 2019, at 9:28 PM, Mark Adams via petsc-dev <petsc-dev at mcs.anl.gov> wrote:
> > > I am seeing this when I pull master into my branch:
> > > "/autofs/nccs-svm1_home1/adams/petsc/src/mat/impls/dense/seq/cuda/densecuda.cu"
> > >           , line 243: error: function call is not allowed in a constant
> > >           expression
> > >   #if PETSC_PKG_CUDA_VERSION_GE(10,1,0)
> > > and I see that this macro does not seem to be defined:
> > > 22:24 master= ~/Codes/petsc$ git grep PETSC_PKG_CUDA_VERSION_GE
> > > src/mat/impls/dense/seq/cuda/densecuda.cu:#if PETSC_PKG_CUDA_VERSION_GE(10,1,0)
