[petsc-dev] Is master broken?
    Mark Adams
    mfadams at lbl.gov
    Fri Aug  2 05:15:41 CDT 2019
No luck.
On Fri, Aug 2, 2019 at 4:04 AM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
>   Please run with the branch barry/2019-09-01/robustify-version-check and
> send configure.log
> > On Aug 1, 2019, at 11:18 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > 12:10 master= ~/petsc-master$ ls arch-summit-dbg64-pgi-cuda
> > bin  externalpackages  include  lib  obj  share  tests
> > 12:11 master= ~/petsc-master$ tar cvfz ../tt.tarz
> arch-summit-dbg64-pgi-cuda/include/petscpkg_version.h arch-summure.log
> > arch-summit-dbg64-pgi-cuda/lib/petsc/conf/configure.log
> > On Thu, Aug 1, 2019 at 12:08 PM Mark Adams <mfadams at lbl.gov> wrote:
> > On Thu, Aug 1, 2019 at 10:30 AM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> >   Send
> > ls arch-linux2-c-debug/include/
> > That is not my arch name. It is something like
> >  arch-linux2-c-debug/include/petscpkg_version.h
> > and configure.log
> > > On Aug 1, 2019, at 5:23 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > > I get the same error with a fresh clone of master.
> > > On Thu, Aug 1, 2019 at 6:03 AM Mark Adams <mfadams at lbl.gov> wrote:
> > > Tried again after deleting the arch dirs and still have it.
> > > This is my branch that just merged master. I will try with just master.
> > > Thanks,
> > > On Thu, Aug 1, 2019 at 1:36 AM Smith, Barry F. <bsmith at mcs.anl.gov>
> wrote:
> > >   It is generated automatically and put in
> arch-linux2-c-debug/include/petscpkg_version.h  this include file is
> included at top of the "bad" source  file crashes so in theory everything
> is in order check that arch-linux2-c-debug/include/petscpkg_version.h
> contains PETSC_PKG_CUDA_VERSION_GE and similar macros. If not send
> configure.lo
> > > check what is in arch-linux2-c-debug/include/petscpkg_version.h it
> nothing or broken send configure.lo
> > >   Barry
> > > > On Jul 31, 2019, at 9:28 PM, Mark Adams via petsc-dev <
> petsc-dev at mcs.anl.gov> wrote:
> > > > I am seeing this when I pull master into my branch:
> > > > "/autofs/nccs-svm1_home1/adams/petsc/src/mat/impls/dense/seq/cuda/
> densecuda.cu"
> > > >           , line 243: error: function call is not allowed in a
> constant
> > > >           expression
> > > >   #if PETSC_PKG_CUDA_VERSION_GE(10,1,0)
> > > > and I see that this macro does not seem to be defined:
> > > > 22:24 master= ~/Codes/petsc$ git grep PETSC_PKG_CUDA_VERSION_GE
> > > > src/mat/impls/dense/seq/cuda/densecuda.cu:#if
> > <petscpkg_version.h><configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190802/f48d11aa/attachment-0001.html>
Type: application/x-tar
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190802/f48d11aa/attachment-0001.tar>
