[petsc-dev] Something changed with SBAIJ on april 17?
    Éric Chamberland
    Eric.Chamberland at giref.ulaval.ca
    Mon Apr 22 15:42:11 CDT 2019
Hi Stefano,
ok, it will be tested tonight.
Meanwhile, I ran on example to extract some information you asked for:
Le 19-04-22 à 18:42, Stefano Zampini a écrit :
> Eric,
> I have update (force pushed) the branch. It should be fixed now, Can
> you please confirm?
> Thanks
> Il giorno lun 22 apr 2019 alle ore 09:00 Stefano Zampini
> <stefano.zampini at gmail.com <mailto:stefano.zampini at gmail.com>> ha scritto:
>     Eric
>     I'll try to reproduce your setting.
>     Few questions.
>     Is your AIJ matrix lA symmetric?
No, it is not.
>     Does it have any block size set?
No, block size is 1.
>     Do you get the error the first time you do mat copy? Or in
>     subsequent ones?
At the first MatCopy... which is following the MatConvert...
Eric
>     Il Lun 22 Apr 2019, 08:41 Éric Chamberland via petsc-dev
>     <petsc-dev at mcs.anl.gov <mailto:petsc-dev at mcs.anl.gov>> ha scritto:
>         Hi,
>         the patch fixed the 1st kind of error I got ("No support for
>         this operation for this object type"), but I still have all
>         the same faulty tests now returning the 2nd error I reported:
>         [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
>         [0]PETSC ERROR: Argument out of range
>         [0]PETSC ERROR: New nonzero at (0,1) caused a malloc
>         Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn off this check
>         [0]PETSC ERROR: Seehttp://www.mcs.anl.gov/petsc/documentation/faq.html  for trouble shooting.
>         [0]PETSC ERROR: Petsc Release Version 3.11.1, unknown
>         [0]PETSC ERROR: /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/BIB/bin/Test.deliMEFPP.dev  <http://Test.deliMEFPP.dev>  on a  named compile by Unknown Sun Apr 21 18:14:41 2019
>         [0]PETSC ERROR: Configure options --prefix=/opt/petsc-master_debug --with-mpi-compilers=1 --with-mpi-dir=/opt/openmpi-1.10.2 --with-cxx-dialect=C++11 --with-make-np=12 --with-shared-libraries=1 --with-debugging=yes --with-memalign=64 --with-visibility=0 --with-64-bit-indices=0 --download-ml=yes --download-mumps=yes --download-superlu=yes --download-superlu_dist=yes --download-parmetis=yes --download-ptscotch=yes --download-metis=yes --download-suitesparse=yes --download-hypre=yes --with-blaslapack-dir=/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64 --with-mkl_pardiso-dir=/opt/intel/composer_xe_2015.2.164/mkl --with-mkl_cpardiso-dir=/opt/intel/composer_xe_2015.2.164/mkl --with-scalapack=1 --with-scalapack-include=/opt/intel/composer_xe_2015.2.164/mkl/include --with-scalapack-lib="-L/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64 -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
>         [0]PETSC ERROR: #1 MatSetValues_SeqSBAIJ() line 992 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/impls/sbaij/seq/sbaij.c
>         [0]PETSC ERROR: #2 MatSetValues() line 1407 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/interface/matrix.c
>         [0]PETSC ERROR: #3 MatAXPY_BasicWithPreallocation() line 171 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/utils/axpy.c
>         [0]PETSC ERROR: #4 MatAXPY() line 52 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/utils/axpy.c
>         [0]PETSC ERROR: #5 MatAYPX() line 348 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/utils/axpy.c
>         [0]PETSC ERROR: #6 MatCopy_Basic() line 4044 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/interface/matrix.c
>         [0]PETSC ERROR: #7 MatCopy_SeqAIJ() line 2844 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/impls/aij/seq/aij.c
>         [0]PETSC ERROR: #8 MatCopy() line 4098 in /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/interface/matrix.c
>         We are calling a MatCopy from an aij (lA) to sbaij (lB) matrix
>         with DIFFERENT_NONZERO_PATTERN option.
>         But on first call, the SBAIJ matrix has first been created
>         then filled with MatConvert call:
>         MatConvert(lA,MATSBAIJ, MAT_INITIAL_MATRIX, &lB);
>         I just noticed we then do a:
>         MatSetOption(lA, MAT_SYMMETRIC, PETSC_FALSE);
>         (I have to find why???....)
>         and on other calls, we call the "faulty" MatCopy with
>         previously created matrices:
>         MatCopy(lA,lB,DIFFERENT_NONZERO_PATTERN);
>         which gives the "Argument out of range" error...
>         Thanks,
>         Eric
>         Le 19-04-21 à 22:52, Éric Chamberland via petsc-dev a écrit :
>>         Hi Stefano,
>>         sure!
>>         configuration is running with your branch and tests will
>>         begin later.  I will see and share the results tomorrow.
>>         thanks! :)
>>         Eric
>>         Le 19-04-21 à 17:21, Stefano Zampini a écrit :
>>>         Eric
>>>         I have opened a PRmay fix the issues you reported
>>>         https://bitbucket.org/petsc/petsc/pull-requests/1571/fix-sbaij/diff
>>>         Could you please try
>>>         https://bitbucket.org/petsc/petsc/branch/stefano_zampini/fix-matcopy-sbaij?
>>>         (off maint)
>>>         Thanks
>>>         Il giorno ven 19 apr 2019 alle ore 23:26 Éric Chamberland
>>>         via petsc-dev <petsc-dev at mcs.anl.gov
>>>             Hi,
>>>             ok, I will try do to one, but since I am on vacation
>>>             right now, I will try to do it at my return in a week.
>>>             I wanted to report the bug asap, so you may figure out
>>>             the problem quickly.
>>>             Thanks,
>>>             Eric
>>>             Le 19-04-19 à 19:10, Stefano Zampini via petsc-dev a écrit :
>>>>             Can you please send a MWE to reproduce the errors so
>>>>             that I can provide a fix?
>>>>             Il Ven 19 Apr 2019, 17:00 Matthew Knepley via petsc-dev
>>>>             ha scritto:
>>>>                 On Fri, Apr 19, 2019 at 9:40 AM Balay, Satish via
>>>>                 <mailto:petsc-dev at mcs.anl.gov>> wrote:
>>>>                     There were a few merges in the the past few days.
>>>>                     For ex:
>>>>                     https://bitbucket.org/petsc/petsc/pull-requests/1547/add-support-for-zeroing-rows-and-columns/diff
>>>>                     Perhaps you can narrow down to the commit that
>>>>                     triggered this change with git bisect.
>>>>                 I think its this commit:
>>>>                 https://bitbucket.org/petsc/petsc/commits/2b4bbc58b197e97e85869bd03594884bbca73c67
>>>>                     Matt
>>>>                     cc: Stefano
>>>>                     Satish
>>>>                     On Fri, 19 Apr 2019, Éric Chamberland via
>>>>                     petsc-dev wrote:
>>>>                     > Hi,
>>>>                     > Looks like something pushed on master change
>>>>                     or broke some sbaij usages.  I
>>>>                     > have two kind off errors with MatCopy:
>>>>                     > 1) MatCopy error saying: No support for this
>>>>                     Message
>>>>                     > [0]PETSC ERROR: No support for this operation
>>>>                     > [0]PETSC ERROR: MatGetRow is not supported
>>>>                     for SBAIJ matrix format. Getting
>>>>                     > the upper triangular part of row, run with
>>>>                     -mat_getrow_uppertriangular, call
>>>>                     MatSetOption(mat,MAT_GETROW_UPPERTRIANGULAR,PETSC_TRUE)
>>>>                     or
>>>>                     > MatGetRowUpperTriangular()
>>>>                     > [0]PETSC ERROR: See
>>>>                     for
>>>>                     > trouble shooting.
>>>>                     > [0]PETSC ERROR: Petsc Development GIT
>>>>                     revision: v3.11.1-277-g63b3610  GIT
>>>>                     > Date: 2019-04-18 08:33:56 -0500
>>>>                     > [0]PETSC ERROR:
>>>>                     > on a  named compile by Unknown Fri Apr 19
>>>>                     03:19:09 2019
>>>>                     --with-visibility=0
>>>>                     > --with-scalapack=1
>>>>                     > [0]PETSC ERROR: #1 MatGetRow_SeqSBAIJ() line
>>>>                     281 in
>>>>                     > [0]PETSC ERROR: #2 MatGetRow() line 574 in
>>>>                     > [0]PETSC ERROR: #3
>>>>                     MatAXPY_Basic_Preallocate() line 138 in
>>>>                     > [0]PETSC ERROR: #4 MatAXPY() line 95 in
>>>>                     > [0]PETSC ERROR: #5 MatAYPX() line 384 in
>>>>                     > [0]PETSC ERROR: #6 MatCopy_Basic() line 4056 in
>>>>                     > [0]PETSC ERROR: #8 MatCopy() line 4110 in
>>>>                     > 2) MatCopy error saying:
>>>>                     > Argument out of range: New nonzero at (6,7)
>>>>                     caused a malloc
>>>>                     Message
>>>>                     > [0]PETSC ERROR: New nonzero at (6,7) caused a
>>>>                     malloc
>>>>                     > Use MatSetOption(A,
>>>>                     turn off
>>>>                     > this check
>>>>                     > [0]PETSC ERROR: See
>>>>                     for
>>>>                     > trouble shooting.
>>>>                     > [0]PETSC ERROR:
>>>>                     /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/BIB/bin/Test.BIBProblemeGD.dev
>>>>                     <http://Test.BIBProblemeGD.dev>
>>>>                     03:22:25 2019
>>>>                     --with-visibility=0
>>>>                     > --with-scalapack=1
>>>>                     line 990 in
>>>>                     > [0]PETSC ERROR: #2 MatSetValues() line 1404 in
>>>>                     > [0]PETSC ERROR: #3
>>>>                     MatAXPY_BasicWithPreallocation() line 209 in
>>>>                     > [0]PETSC ERROR: #4 MatAXPY() line 96 in
>>>>                     > Here are my installation logs as of april 18,
>>>>                     at 02h00:
>>>>                     http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_configure.log
>>>>                     http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_make.log
>>>>                     http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_default.log
>>>>                     http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_RDict.log
>>>>                     http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_CMakeLists.txt
>>>>                     http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_make_test.log
>>>>                     http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2019.04.18.02h00m01s_make_streams.log
>>>>                     > Thanks,
>>>>                     > Eric
>>>>                 What most experimenters take for granted before
>>>>                 they begin their experiments is infinitely more
>>>>                 interesting than any results to which their
>>>>                 experiments lead.
>>>>                 -- Norbert Wiener
>>>>                 https://www.cse.buffalo.edu/~knepley/
>>>>                 <http://www.cse.buffalo.edu/~knepley/>
>>>         Stefano
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190422/ee53d755/attachment-0001.html>
