[petsc-dev] testing in parallel
    Stefano Zampini
    stefano.zampini at gmail.com
    Mon Apr 22 15:11:16 CDT 2019
The print-test target seems ok wrt race conditions
[szampini at localhost petsc]$ make -j1 -f gmakefile.test print-test  globsearch="mat*" | wc
      1     538   11671
[szampini at localhost petsc]$ make -j20 -f gmakefile.test print-test  globsearch="mat*" | wc
      1     538   11671
However, if I run the tests, I get two different outputs
[szampini at localhost petsc]$ make -j20 -f gmakefile.test test globsearch="mat*"
#   Summary
# success 1226/1312 tests (93.4%)
# failed 0/1312 tests (0.0%)
# todo 6/1312 tests (0.5%)
# skip 80/1312 tests (6.1%)
#   Summary
# success 990/1073 tests (92.3%)
# failed 0/1073 tests (0.0%)
# todo 6/1073 tests (0.6%)
# skip 77/1073 tests (7.2%)
> On Apr 22, 2019, at 8:12 PM, Jed Brown <jed at jedbrown.org> wrote:
> Stefano Zampini via petsc-dev <petsc-dev at mcs.anl.gov> writes:
>> Scott,
>> I have noticed that make -j20 -f gmakefile.test test globsearch="mat*" does
>> not always run the same number of tests. How hard is to fix this race
>> condition in the generation of the rules?
> Can you reproduce with the print-test target?  These are just running
> Python to create a list of targets, and should all take place before
> executing rules.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20190422/ff262cb6/attachment.html>
