[petsc-dev] testing in parallel
Jed Brown
jed at jedbrown.org
Mon Apr 22 12:12:49 CDT 2019
Stefano Zampini via petsc-dev <petsc-dev at mcs.anl.gov> writes:
> Scott,
> I have noticed that make -j20 -f gmakefile.test test globsearch="mat*" does
> not always run the same number of tests. How hard is to fix this race
> condition in the generation of the rules?
Can you reproduce with the print-test target? These are just running
Python to create a list of targets, and should all take place before
executing rules.
