[petsc-dev] Adding an enum value back to KSPConvergedReason
Balay, Satish
balay at mcs.anl.gov
Tue Apr 9 14:53:56 CDT 2019
Here is another thread on this issue
https://lists.mcs.anl.gov/pipermail/petsc-dev/2019-April/024237.html
Jed has the fix - which is now in a PR
https://bitbucket.org/petsc/petsc/pull-requests/1528/ksp-correctly-deprecate/diff
Satish
On Tue, 9 Apr 2019, Wells, David via petsc-dev wrote:
> Dear PETSc developers,
> Congratulations on the 3.11 release.
> I am a libMesh user and noticed that a small change made in commit c0decd05c6 (renaming KSP_DIVERGED_PCSETUP_FAILED to KSP_DIVERGED_PC_FAILED) breaks compatibility with all recent libMesh releases. The libMesh developers know about this but have not yet released a compatible version of libMesh.
> Would it be possible to restore the old enum value for compatibility with older versions of libMesh? I can put together a PR if folks are interested.
> Best,
> David Wells
