[petsc-dev] tiny issues in test harness
Scott Kruger kruger at txcorp.com
Wed Sep 26 16:00:49 CDT 2018
Fix for #1 is merged into next.
See ecc1beb596a8093f7509ca38016ed30c93784193
For #2, I think it'll work if you use double quotes and egrep.
If you do this:
cd $PETSC_DIR/src/sys/examples/test
grep filter *.c
I think you'll see some examples of complicated filters that Barry got
working.
Scott
On 8/14/18 4:05 AM, Jakub Kruzik wrote:
> Hi all,
> I started using test harness in PERMON and find out a couple of issues
> with it.
> 1) multiple "args:" keywords in "test:" in "testset:" are ignored except
> for the last "args:" keyword. See attached MWE and check it with
> python2 ${PETSC_DIR}/config/testparse.py -t ex1.c -v 3
> 2) single quotes can't be used in "filter:"  keyword. E.g. filter: grep
> 'r =' generates
> petsc_testrun ... 'grep 'r =''
> resulting in filter being "grep r". Might be worth mentioning this in
> dev manual and/or putting guards into parsing/petsc_testrun.
> Best,
> Jakub
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
Boulder, CO 80303                Fax:   (303) 448-7756
