[petsc-dev] PETSC_HAVE_COMPLEX vs PETSC_USE_COMPLEX
Hapla Vaclav
vaclav.hapla at erdw.ethz.ch
Wed Sep 26 12:21:23 CDT 2018
Oh I see, thanks for clarification.
> 26. 9. 2018 v 19:20, Jed Brown <jed at jedbrown.org>:
> PETSC_HAVE_COMPLEX means that PetscComplex is defined.
> PETSC_USE_COMPLEX means that PetscScalar is complex.
> Hapla Vaclav <vaclav.hapla at erdw.ethz.ch> writes:
>> Hello
>> grep -R PETSC_HAVE_COMPLEX $PETSC_DIR/src
>> gives quite some occurrences.
>> It should be PETSC_USE_COMPLEX, right?
>> Vaclav
