[petsc-dev] git repo branches housekeeping
Satish Balay
balay at mcs.anl.gov
Wed Sep 12 10:31:28 CDT 2018
On Wed, 12 Sep 2018, Balay, Satish wrote:
> For more housekeeping - look at the remaining local and remote
> branches and figure-out what to do. [perhaps some of them are
> intermediate branches during rebase - or abandoned features that
> should be deleted].
For reference - current list of remote branches
Satish
$ git branch -r |wc -l
272
$ git branch -r
origin/BarryFSmith/readmemd-created-online-with-bitbucket-1506004176072
origin/Fande-Kong/generalize_hierarchical_partitioning_maint
origin/Fande-Kong/hypre_mat_type
origin/HEAD -> origin/master
origin/adams/zeroDSOR
origin/balay/atpesc-tutorial-2014-bgq
origin/balay/atpesc-tutorial-2015-bgq
origin/balay/atpesc-tutorial-2016-bgq
origin/balay/atpesc18
origin/balay/fix-ctable-hash-again/maint
origin/balay/fix-cxx-cmplx-single
origin/balay/fix-rebuild-xsdktrilinos
origin/balay/fix-superlu_dist-reuse-factornumeric1-maint-backport
origin/balay/fix-uninstall
origin/balay/giturl-fixes
origin/balay/k-fujitsu-f90-v3.6
origin/balay/release-3.10-revert-to-dev
origin/balay/test
origin/balay/to-maint-switch-hdf5-build-to-cmake
origin/balay/update-builder-test
origin/balay/update-elemental-nov-2016
origin/balay/update-hdf5-1.10.2
origin/balay/update-strumpack-2.2.0
origin/barry-test
origin/barry/combblas
origin/barry/feature-baij-blockdiagonal-scale
origin/barry/feature-petscviewerformat-register
origin/barry/feature-snessetkspsetupcallback
origin/barry/fix-zoltan-library-list/maint
origin/barry/improve-secant-linesearch
origin/barry/mg-presmooth-zero-initial-guess
origin/barry/oana/spectral-toy-updates
origin/barry/pyjac
origin/barry/refactor-vecscatter-2
origin/barry/refactor-vecview
origin/barry/saws-profile
origin/barry/spectral-poisson
origin/barry/ssisc-spectral-adjoint
origin/bueler/clean-ex9
origin/dalcinl/fix-xaij-spd
origin/dalcinl/math-isclose
origin/dalcinl/ts-snes
origin/damalbel/dmnetwork_nest
origin/damalbel/dmnetwork_nest_fieldsplit
origin/debo/mat-taij
origin/debo/ts-fix-ex31
origin/debo/ts-irk
origin/denera/mat-lmvm-symbrdn-rescaling-fix
origin/denera/petsc-jenkins-integration
origin/denera/snes-reasonview-indent-fix
origin/denera/tao-anderson-multisecant
origin/denera/tao-gauss-newton-wrapper
origin/denera/tao-linesearch-redesign
origin/denera/tao-lmvm-recycling-bounded-refactor
origin/denera/tao-problem-type-infrastructure
origin/denera/tao-six-hump-camel-problem
origin/dmay/ksp-cvgtest-normtype-fix
origin/emil/add-fortran-ts-pre-post-stage-step/maint
origin/emil/fix-ts-dae-rebased-v2
origin/emil/ts-ex31-add-pg-example
origin/emil/ts-steady-state-ex31
origin/hongzh/index1-dae
origin/hongzh/remove-manual-unrolling
origin/hongzh/swe
origin/hongzh/timing_issue
origin/hongzh/ts-adjoint2
origin/hongzh/ts-matshell-example
origin/hongzh/vectorize-inner-products
origin/hzhang/add-matcompress
origin/hzhang/dmnetwork-couple
origin/hzhang/fix-mpi3_unusedvar
origin/hzhang/fix-ptaptest
origin/hzhang/ksp-fminres
origin/hzhang/ksp-minresqlp
origin/hzhang/vec_node/master
origin/hzhang/vec_node/master-rebased
origin/irving/fe-scalars
origin/irving/snes-ex12-cleanup
origin/jczhang/feature-vecscatter-mpi3shmem
origin/jczhang/feature-vecscatter-neighborhood
origin/jczhang/optimize-double-agent-mpi
origin/jczhang/optimize-on-node-matrix
origin/jed/assembly-perf
origin/jed/cray-externc
origin/jed/defined-nocpp
origin/jed/doc-xsetdm
origin/jed/elbueler-snes-ex5-fixes
origin/jed/feature-dmda-section
origin/jed/feature-sf-local
origin/jed/fix-dmplexdistribute-fortran
origin/jed/fix-gpu-docs
origin/jed/fix-mat-convert-basic-bs
origin/jed/ksp-plugin
origin/jed/make-lib-ordering
origin/jed/mat-eigenvalue-cache
origin/jed/mat-hash
origin/jed/mat-kaij
origin/jed/mat-taij
origin/jed/matbaij-loop
origin/jed/matzerorowscolumnslocal-null/maint
origin/jed/mpi-2
origin/jed/next-seaice
origin/jed/sr-driver
origin/jed/sr-driver4
origin/jed/tao-status-string
origin/jed/tap
origin/jed/testsrcs-refresh
origin/jed/ts-ex11-union
origin/jed/ts-heat-plex
origin/jed/vecghostgetvalues
origin/john-saws-webosocket-update
origin/john/saws-webui-upgrade
origin/karlrupp/feature-fast-matmatmult
origin/karlrupp/feature-optimize-opencl-petscfe
origin/karlrupp/feature-pipelined-cg-viennacl
origin/karlrupp/feature-viennacl-cuda
origin/karlrupp/feature-viennacl-openmp
origin/karlrupp/fix-viennacl-veccopy
origin/karpeev/fix-pc-fieldsplit-reset
origin/karpeev/mat-convert-nest-aij-test
origin/karpeev/mat-reset
origin/klaij/fieldsplit-simple-ex70
origin/knepley/feature-configure-kcomputer
origin/knepley/feature-da-repartition
origin/knepley/feature-dm-nearnullspace
origin/knepley/feature-error-logging
origin/knepley/feature-ksp-ex10-transpose
origin/knepley/feature-nonlinear-convergence
origin/knepley/feature-optcontrol-mg
origin/knepley/feature-plex-example-nonconforming
origin/knepley/feature-plex-hdiv
origin/knepley/feature-plex-l2-projection
origin/knepley/feature-plex-libmesh-support
origin/knepley/feature-plex-nasm
origin/knepley/feature-plex-nonaffine-geometry
origin/knepley/feature-plex-snesvi-example
origin/knepley/feature-section-field-major
origin/knepley/feature-snes-rewrite
origin/knepley/feature-spectral-solutions
origin/knepley/fix-plex-hdf5-periodic
origin/knepley/fix-quadrature-order
origin/knepley/ibamr
origin/knepley/pylith
origin/madams/ex56params
origin/madams/sor-residual
origin/madams/sr-driver
origin/madams/sr-driver2
origin/madams/sr-driver4
origin/madams/sr1
origin/maint
origin/maint-3.2
origin/maint-3.3
origin/maint-3.4
origin/maint-3.5
origin/maint-3.6
origin/maint-3.7
origin/maint-3.8
origin/maint-3.9
origin/maint-tao-2.2
origin/mark/aij-overlap
origin/mark/dm-bs-bug
origin/mark/dmplex-generalize-periodicity
origin/mark/ex48-jacobian
origin/mark/feature-picell
origin/mark/feature-plex-l2-projection
origin/mark/fix-aijmkl
origin/mark/fix-mat2
origin/mark/mat-fix-scale
origin/mark/plex-tuts
origin/mark/ts-ex11-mhd
origin/master
origin/master-tao
origin/mlange/feature-plex-case
origin/mlange/feature-plex-create-parallel
origin/mlange/feature-plex-triangle
origin/mlange/fix-adjacency-performance
origin/mlange/fix-plex-cas-tests
origin/mlange/fix-plex-hex-mesh
origin/mlange/plex-create-parallel
origin/mlange/plex-distributed-overlap
origin/mlange/plex-hybrid-hdf5
origin/mlange/plex-redistribute
origin/mlange/plex-sfc-reordering
origin/mlange/plex-vertex-partitioning
origin/mlange05/fix-gmsh-coordinates
origin/next
origin/next-jun-2018
origin/next-sep-2018
origin/next-tmp
origin/oana/inverse_problems
origin/oana/spectral-toy
origin/paulmullowney/aijcusp-ellpack-fix
origin/pefarrell/dmshell-asm
origin/pefarrell/nasm-fixes
origin/peller/threadcomm
origin/pr118/asmunder/DMDA-fortran-example/master
origin/pr478/pfarrell/feature-dmplex-adapt
origin/pr600/dmeiser/feature-examples-newmethod/master
origin/prbrune/matcoloring-creategraph
origin/prbrune/matcoloring-minpack
origin/prbrune/matcoloring-misimprovement
origin/prbrune/matcoloring-zoltan
origin/prbrune/pcgamg-bootstrap
origin/prbrune/pcgamg-classicalbootstrap
origin/prbrune/pcgamg-cr
origin/prbrune/sf-examplefix
origin/prbrune/snes-ex19vtkoutput
origin/prbrune/snes-fasadditive
origin/prbrune/zoltanupdate
origin/psanan/ts-bz-examples
origin/psanan/ts-multiscale
origin/psanan/ts-rhs-partitions
origin/psanan/ts-tests
origin/rmills/feature-aijmkl-optional-sparse-optimize
origin/rmills/feature-gamg-use-matsell
origin/rmills/fix-sell-matconvert
origin/sarich/feature-submatrixfree
origin/sarich/feature-tao-pounders-jacobian
origin/sarich/fix-alquimia-static
origin/sarich/mira
origin/sarich/snesvi-subvec-options
origin/sarich/tao-pounders-add-corr-test
origin/scott/change-NO_RM-default
origin/scott/documentation-walker
origin/scott/test-harness-debugger
origin/scott/update-dm-dt-output
origin/shri/FTRTDS-project
origin/shri/dmnetwork-subnetworks
origin/shri/ts-dae-semi-explicit
origin/shri/ts-event-initialization
origin/shri/ts-powergrid
origin/stefano_zampini/feature-continuousadjoint
origin/stefano_zampini/feature-mataij-to-matis-rebased
origin/stefano_zampini/feature-newmattype-elementlist
origin/stefano_zampini/feature-pcgamg-useamat
origin/stefano_zampini/feature-simplex2tensor-refinement-hybrid
origin/stefano_zampini/new-elemental-interface
origin/tisaac/buildsystem-feature-parallel
origin/tisaac/buildsystem-feature-subst-link-flags
origin/tisaac/config-fix-petsc-py
origin/tisaac/darcy-inference
origin/tisaac/dm-project-function-label
origin/tisaac/dt-feature-vectur-quadrature
origin/tisaac/dual-space-get-traces
origin/tisaac/feature-dmfield-orig
origin/tisaac/feature-fe-integrate-nonaffine
origin/tisaac/feature-gamg-compose-graph
origin/tisaac/feature-petsc4py-subtree
origin/tisaac/feature-picell
origin/tisaac/feature-plex-example-nonconforming
origin/tisaac/feature-seqaij-get-submat-row-unordered
origin/tisaac/feature-seqaij-submat-col-unsorted
origin/tisaac/feature-space-pminus
origin/tisaac/feature-test-maxiter-filter
origin/tisaac/fix-gamg-set-coordinates
origin/tisaac/fix-height-ds
origin/tisaac/gamg-more-info
origin/tisaac/knepley/feature-composable-callbacks
origin/tisaac/ksp-fix-cheby-pc-handling
origin/tisaac/master-merge-mark-snesex56
origin/tisaac/moab-update
origin/tisaac/pc-pbjacobi-vec-get-array-read
origin/tisaac/petsc-next-upstream
origin/tisaac/plex-descriptive-debug
origin/tisaac/plex-feature-vec-get-star
origin/tisaac/plex-fv-without-ghosts
origin/tisaac/update-p4est
origin/tisaac/warn-next-upstream
origin/tmunson/tao-feature-hessian-lagrangian
origin/tmunson/tao-fix-leastsquares-tests
origin/tmunson/tao-upgrade-tron
origin/vi/snes-newtonaugas
