[petsc-dev] git repo branches housekeeping
Balay, Satish
balay at mcs.anl.gov
Wed Sep 12 10:26:57 CDT 2018
ref: https://lists.mcs.anl.gov/pipermail/petsc-dev/2018-April/022748.html
I've deleted all development branches that are already merged into
maint (v3.10) from https://bitbucket.org/petsc/petsc
However if you wish to remove these branches from your clone - it has
to be done manually (in each clone).
To get this list of branches to delete - you can do:
git branch --merged v3.10 |egrep -v " (maint|master|next)" > branches_to_delete
After *verifying* the list is correct - and ok to delete - they can be
deleted with:
git branch -d `cat branches_to_delete`
And to sync the [deleted] remote branch list info - you can do:
git fetch -p
For more housekeeping - look at the remaining local and remote
branches and figure-out what to do. [perhaps some of them are
intermediate branches during rebase - or abandoned features that
should be deleted]. For my branches - I would do:
git branch
git branch -r |grep balay
Satish
reference for self:
$ git branch -r --merged v3.10 |egrep -v origin/\(maint\|master\|next\) |sed -e s%origin/%:% > remote_branches_to_delete
$ git push -u origin `cat remote_branches_to_delete` | tee delete_branches.log
To bitbucket.org:petsc/petsc.git
- [deleted] Fande-Kong/Fixed_SNESTestJacobian_maint
- [deleted] Fande-Kong/hypre_mat_type_maint
- [deleted] Fande-Kong/partition_weights_maint
- [deleted] Fande-Kong/party_distributed
- [deleted] adenchfield/tao-bncg-diagonal-scaling
- [deleted] balay/add-arm-testbuild/maint
- [deleted] balay/add-externalpackage-mirror/maint
- [deleted] balay/arm-fix-checkPIC/maint
- [deleted] balay/builds-cleantest
- [deleted] balay/buildtest-cleanfiles/maint
- [deleted] balay/check-bfort-version/maint
- [deleted] balay/clean-example-makefile-compile-targets
- [deleted] balay/cleanup-vecscatters
- [deleted] balay/fix-F90Array__Destroy/maint
- [deleted] balay/fix-RM-true
- [deleted] balay/fix-analyzer-warning-ex51/maint
- [deleted] balay/fix-confusing-configure-dir-options
- [deleted] balay/fix-cxx-examples-target/maint
- [deleted] balay/fix-ex54f-out/maint
- [deleted] balay/fix-examples-timeout/maint
- [deleted] balay/fix-f2003-check/maint
- [deleted] balay/fix-fftw-check/maint
- [deleted] balay/fix-gmake-check/maint
- [deleted] balay/fix-ibm-xl-compilers/maint
- [deleted] balay/fix-make-check-f90-132limit/maint
- [deleted] balay/fix-missing-fortran-PetscComplex/maint
- [deleted] balay/fix-missing-mpi_c_double_complex/maint
- [deleted] balay/fix-mkl_sparse_detection/maint
- [deleted] balay/fix-namespace-wrt-openmpi/maint
- [deleted] balay/fix-netcdf-zlib-dep/maint
- [deleted] balay/fix-opensolaris-linker-scope-warnings/maint
- [deleted] balay/fix-pr879-jczhang-optimize-vecscatter-multi-copy
- [deleted] balay/fix-prefix-install-alltests
- [deleted] balay/fix-prefix-install-relpath/maint
- [deleted] balay/fix-sundials-build-with-openmpi/maint
- [deleted] balay/fix-test-parmetis-dep/maint
- [deleted] balay/fix-tree-requiresdefine/maint
- [deleted] balay/fix-uni-ex/maint
- [deleted] balay/fix-use-dsymutil-check/maint
- [deleted] balay/fix-vs-memmove-check/maint
- [deleted] balay/fix-win-dll-issues/maint
- [deleted] balay/jenkins-cleantest
- [deleted] balay/jenkins-cleantest-2
- [deleted] balay/mswin-fortran-dll
- [deleted] balay/remove-Regression.py
- [deleted] balay/remove-superlu_mt
- [deleted] balay/rename-vec-tut-ex1f-to-F90/maint
- [deleted] balay/reorg-tests/maint
- [deleted] balay/revert-icc-tgamma-mathimf/maint
- [deleted] balay/speedup-download-cmake/maint
- [deleted] balay/split-petscdmmod.F/maint
- [deleted] balay/switch-matlab-html-doc/maint
- [deleted] balay/update-cmake-3.11.1/maint
- [deleted] balay/update-fftw-3.3.7
- [deleted] balay/update-hdf5-url/maint
- [deleted] balay/update-mac-pgi-test/maint
- [deleted] balay/update-make-gcc8/maint
- [deleted] balay/update-make-l/maint
- [deleted] balay/update-petsc4py-3.9.0/maint
- [deleted] balay/update-petsc4py-latest
- [deleted] balay/update-scotch_6.0.6
- [deleted] balay/update-superlu_dist_v5.4.0
- [deleted] balay/win-shlib-check/maint
- [deleted] balay/workarround-cmake-cxx11/maint
- [deleted] barry/CoDiPack
- [deleted] barry/add-c-bind-fortran-example
- [deleted] barry/add-missing-prototypes/maint
- [deleted] barry/add-mpivpbjacobi
- [deleted] barry/add-test
- [deleted] barry/adios
- [deleted] barry/adios2
- [deleted] barry/allow-snes-unlimited-function-evaluations
- [deleted] barry/always-mpich-enable-error-messages=all
- [deleted] barry/bugfix-petscformatconvert
- [deleted] barry/change-fortran-null
- [deleted] barry/change-fortran-null-fixup
- [deleted] barry/clarify-dmplex-documentation
- [deleted] barry/critical-point-divide-by-zero/maint
- [deleted] barry/dmda-calls-type-check
- [deleted] barry/dmdasetblockfillsparse
- [deleted] barry/error-if-indefinite-pc-cg
- [deleted] barry/feature-3d-dmda-mirror
- [deleted] barry/feature-PCVPBJACOBI
- [deleted] barry/feature-matlab-socket/maint
- [deleted] barry/fix-PetscSNPrintfCount-percentg
- [deleted] barry/fix-ex94-tolerances/maint
- [deleted] barry/fix-fortran-matsetvaluesblocked/maint
- [deleted] barry/fix-gamg-hash-large-ints-maint
- [deleted] barry/fix-insanity-netcdf/maint
- [deleted] barry/fix-mat-getdiagonal-shell-has-operation
- [deleted] barry/fix-mat-new-nonzero-locations/maint
- [deleted] barry/fix-mat-subclass-set/maint
- [deleted] barry/fix-matgetdiagonal-shell
- [deleted] barry/fix-negative-dmda-sizes/maint
- [deleted] barry/fix-null-matrix-set-jacobian/maint
- [deleted] barry/fix-options-table/maint
- [deleted] barry/fix-pardiso/maint
- [deleted] barry/fix-pcapplytranspose_asm/maint
- [deleted] barry/fix-petscstrlcat/maint
- [deleted] barry/fix-richardson-zero-iterations-sor/maint
- [deleted] barry/fix-veccreateghostblockwitharray/maint
- [deleted] barry/fix-vecgetarrayscatter
- [deleted] barry/fix/matmffdsetbase-fortran-null
- [deleted] barry/fortran-object-initialize-zero/maint
- [deleted] barry/gamghash-cleanup
- [deleted] barry/improve-snes_test_jacobian
- [deleted] barry/libceed
- [deleted] barry/log-nested-begin-fixes/maint
- [deleted] barry/matgetownershipis-fortran/maint
- [deleted] barry/matlab-mkl-fix/maint
- [deleted] barry/monitor-ts-extrem
- [deleted] barry/refactor-vecscatter
- [deleted] barry/rm-DMDASplitComm2d
- [deleted] barry/rm-common-blocks-part-1
- [deleted] barry/rm-common-blocks-part-2
- [deleted] barry/rm-common-blocks-part-3
- [deleted] barry/rm-fshift-error-hack-sor/maint
- [deleted] barry/rm-fsolvebaij
- [deleted] barry/rm-unneeded-dmda-includes
- [deleted] barry/rm-with-errorchecking
- [deleted] barry/submansec-moab
- [deleted] barry/trim-vecscatter
- [deleted] barry/update-petscstrncpy
- [deleted] barry/use-chkerrmpi
- [deleted] dalcinl/fix-python3/maint
- [deleted] dalcinl/options
- [deleted] denera/ksp-gltr-memleak-fix
- [deleted] denera/lmvm-mat-and-pc
- [deleted] denera/lmvm-symbrdn-scale-fix
- [deleted] denera/mat-lmvm-sym-bad-brdn
- [deleted] denera/mat-lmvm-symbrdn-diag-init
- [deleted] denera/petsc-jenkins-junit-xml
- [deleted] denera/petsc-jenkins-xml-script-fix
- [deleted] denera/petsc-submat-virtual-shift
- [deleted] denera/petsc-tao-docs-update
- [deleted] denera/tao-blmvm-recycle-missing-example
- [deleted] denera/tao-bnk-64bit-index-fix
- [deleted] denera/tao-bnk-warning-fixes
- [deleted] denera/tao-bounded-newton
- [deleted] denera/tao-custom-monitor-bugfix
- [deleted] denera/tao-linesearch-monitor
- [deleted] denera/tao-merge-pgd-into-bncg
- [deleted] denera/tao-separate-quadratic-solvers
- [deleted] denera/tao-smonitor-tablevel-fix
- [deleted] dmay/dmc-edited-online-with-bitbucket-1533632371795
- [deleted] elbueler/snes-ex9-better
- [deleted] haplav/feature-dmplex-distributed-hdf5-read
- [deleted] haplav/feature-ksplsqr-matnorm-test
- [deleted] haplav/fix-and-test-least-squares
- [deleted] haplav/fix-isgeneral/maint
- [deleted] haplav/plex-throw-error-if-viewer-type-unsupported
- [deleted] haplav/testupdate-dmplex-ex5-avoid-chaco
- [deleted] hongzh/fix-64bit-knl-build/maint
- [deleted] hongzh/fix-hessian-test
- [deleted] hongzh/fix-rk-adjoint/maint
- [deleted] hongzh/fix-rk-integral/maint
- [deleted] hongzh/fix-ts-ex21/maint
- [deleted] hongzh/fix-tstraj
- [deleted] hongzh/guard-fma-intrinsics/maint
- [deleted] hongzh/inverse-initial-value-problem
- [deleted] hongzh/rename-bsi
- [deleted] hongzh/separate-tssen-from-ts
- [deleted] hongzh/symplectic-integrator
- [deleted] hongzh/update-dev-notes
- [deleted] hzhang/fix-pc-fieldsplit-reuse
- [deleted] hzhang/fix-vecscat_mpi3
- [deleted] hzhang/fix-vecscatter-mpi3
- [deleted] hzhang/mumps-spRHS
- [deleted] hzhang/update-example-ts-pipes1
- [deleted] jczhang/feature-mumps-omp
- [deleted] jczhang/fix-a-typo
- [deleted] jczhang/fix-manual-profiling-figs/maint
- [deleted] jczhang/fix-perf-log-stage
- [deleted] jczhang/fix-pr1022-optimize-vecscatter-with-memcpy
- [deleted] jczhang/fix-pr1101-feature-mumps-omp
- [deleted] jczhang/fix-sparse-dense-dot-kernels/maint
- [deleted] jczhang/optimize-vecscatter-with-memcpy
- [deleted] jczhang/test-vecscatter-event-log
- [deleted] jed/cholesky-sym
- [deleted] jed/config-prefix-install
- [deleted] jed/const-XType
- [deleted] jed/fix-matdensegetarrayf90/maint
- [deleted] jed/fix-mpi-macros/maint
- [deleted] jed/gfortran8-strlen-type/maint
- [deleted] jed/matsolverpackage-deprecate-stubs/maint
- [deleted] jed/mpiuni-include/maint
- [deleted] jed/tao-typedef
- [deleted] jose/fix-float128
- [deleted] jose/fix-petscmath
- [deleted] karlrupp/feature-faster-tests
- [deleted] karlrupp/feature-test-harness-detailed-timings
- [deleted] karlrupp/fix-cuda-complex-builds
- [deleted] karlrupp/fix-curl-stderr
- [deleted] karlrupp/jenkins-arches
- [deleted] knepley/doc-fixed-manpage-for-pcfieldsplitsetsch-1531307070802
- [deleted] knepley/feature-configure-ibamr-packages
- [deleted] knepley/feature-pc-patch
- [deleted] knepley/feature-plex-bdjacobian-single
- [deleted] knepley/feature-plex-debugging
- [deleted] knepley/feature-plex-elasticity-test
- [deleted] knepley/feature-plex-functionals
- [deleted] knepley/feature-plex-parallel-submesh
- [deleted] knepley/feature-snes-ex13-spectral
- [deleted] knepley/fix-dm-gmg
- [deleted] knepley/fix-dmfield-surface
- [deleted] knepley/fix-ex62-tests
- [deleted] knepley/fix-fe-bd-integral
- [deleted] knepley/fix-fe-vector-spaces
- [deleted] knepley/fix-plex-bd-int
- [deleted] knepley/fix-plex-jacobian-action
- [deleted] knepley/fix-plex-pointfunc-dim
- [deleted] knepley/fix-plex-project-tests
- [deleted] knepley/fix-plex-residual-loop
- [deleted] knepley/fix-plex-submesh-projection
- [deleted] knepley/fix-plex-vtk
- [deleted] knepley/fix-section-clone
- [deleted] knepley/fix-snes-ex69
- [deleted] knepley/fix-superdm-is
- [deleted] knepley/petscspace-improved-documentation-for-pe-1536146176280
- [deleted] knepley/test
- [deleted] mark/bib-new
- [deleted] mark/fix-gamg-tests
- [deleted] mark/gamg-comment
- [deleted] mark/gamg-doc
- [deleted] mark/gamg-doc2
- [deleted] pr1015/mapdes/plex-partition-balance/master
- [deleted] pr1018/minrk/gcc_ext_system_lib/maint
- [deleted] pr1042/a_selinger/feature-matmatmult/master
- [deleted] pr1055/a_selinger/feature-matsetvalues/master
- [deleted] pr1061/a_selinger/feature-faster-scalable-matmatmult/master
- [deleted] pr1079/jkruzik/jkruzik/fix-gcov-obj-path/master
- [deleted] pr1081/a_selinger/matsetvalues-ptap/master
- [deleted] pr1085/mapdes/matnullspacetest-optionsprefix/master
- [deleted] pr1086/aselinger/MatTranspose_SeqAIJ_FAST/master
- [deleted] pr1095/aselinger/faster_MatTranspose_MPIAIJ/master
- [deleted] pr1107/mpigou/fix-configure-error-if-include-directory/master
- [deleted] pr1112/prj-/feature-default-boomeramg-smoothers/master
- [deleted] pr930/tmijieux/pipelcg-with-shifts-and-precond/master
- [deleted] pr935/sepideh/ghosted-X_t/master
- [deleted] pr983/al007/examples-stuck-newton/master
- [deleted] psanan/39html-edited-online-with-bitbucket-1533285733747
- [deleted] psanan/dacreatec-edited-online-with-bitbucket-1530257465014
- [deleted] psanan/deprecate-options
- [deleted] psanan/deprecate-options-fixes
- [deleted] psanan/developerstex-edited-online-with-bitbuck-1533976829212
- [deleted] psanan/devmanual-regression-cleanup
- [deleted] psanan/dm-compatibility
- [deleted] psanan/dmda-compatibility
- [deleted] psanan/dmda-deprecate-dmdagetreduceddmda
- [deleted] psanan/dmda-rename-reduced
- [deleted] psanan/dmda-uniformcoords-check-fix
- [deleted] psanan/doc-dmsetcoordinates-manpage-fixes
- [deleted] psanan/docs-devmanual-deprecation
- [deleted] psanan/docs-handson-ref-update
- [deleted] psanan/grvtkc-edited-online-with-bitbucket-1530109267911
- [deleted] psanan/makefile-edited-online-with-bitbucket-1528215844762
- [deleted] psanan/manpages-notes-newlines
- [deleted] psanan/namespace-sr-constants
- [deleted] psanan/part1tex-edited-online-with-bitbucket-1532696753342
- [deleted] psanan/pc-fieldsplit-detect-interface
- [deleted] psanan/petscdmh-edited-online-with-bitbucket-1530109968738
- [deleted] psanan/petscdmtypesh-edited-online-with-bitbuck-1529421481118
- [deleted] psanan/test-instructions-makefile-name-fix
- [deleted] psanan/vtk-viewer-dmda-dof
- [deleted] rmills/doc-fix-snesaspin-formatting/maint
- [deleted] rmills/feature-add-mataijsell
- [deleted] rmills/fix-aijmkl-add-MatPtAP_is_seqaijmkl
- [deleted] rmills/fix-aijmkl-comment
- [deleted] rmills/fix-aijmkl-deprecated-calls
- [deleted] rmills/fix-aijmkl-no_spmv2-mkl-18u2/maint
- [deleted] rmills/fix-aijmkl-replace-ifdefs
- [deleted] rmills/fix-aijmkl-sypr/maint
- [deleted] rmills/fix-aijmkl-unused-variables/maint
- [deleted] rmills/fix-aijperm-add-MatPtAP_is_seqaijperm
- [deleted] rmills/fix-baijmkl-replace-ifdefs
- [deleted] rmills/fix-dm-replace-ifdefs
- [deleted] rmills/fix-matsell-no-matconvertbasic/maint
- [deleted] rmills/fix-matseqsellsetpreallocation-typo
- [deleted] scott/test-harness-perform2
- [deleted] stefano_zampini/cherrypick/maint
- [deleted] stefano_zampini/feature-fieldsplit-innerkspwithpcksp
- [deleted] stefano_zampini/feature-mataij-to-matis
- [deleted] stefano_zampini/feature-mataij-to-matis-rebased-final
- [deleted] stefano_zampini/feature-matis-ptap-aij
- [deleted] stefano_zampini/feature-ptatin3d-support
- [deleted] stefano_zampini/feature-simplex2tensor-refinement-hybrid-master
- [deleted] stefano_zampini/few-fixes-before-release
- [deleted] stefano_zampini/fix-tabs/maint
- [deleted] stefano_zampini/fixes-for-maint/maint
- [deleted] tisaac/feature-dmfield
- [deleted] tisaac/feature-space-tensor
- [deleted] tmunson/tao-pounders-bug-fixes
- [deleted] tmunson/tao-pounders-matlab-interface
