[petsc-dev] PETSc 3.10: September 4, 2018, is the cutoff-date for new features
Balay, Satish
balay at mcs.anl.gov
Wed Sep 12 07:59:27 CDT 2018
All release relevant PRs are now merged to master. And I'm ready to tag the release [and spin the tarballs]
Any potential (code, doc) fixes can be queued for 3.10.1
Satish
On Tue, 11 Sep 2018, Satish Balay wrote:
> Reminder!
> please check
> http://www.mcs.anl.gov/petsc/documentation/changes/dev.html and update
> src/docs/website/documentation/changes/dev.html with relavent changes.
> Thanks,
> Satish
> On Mon, 10 Sep 2018, Satish Balay wrote:
> > Also - please check and update src/docs/website/documentation/changes/dev.html as needed.
> > Thanks,
> > Satish
> > On Wed, 5 Sep 2018, Karl Rupp wrote:
> > > Dear PETSc developers,
> > > please open any outstanding pull requests for the upcoming PETSc 3.10 release
> > > in the next few hours. After that, please do not merge anything to `next` or
> > > `master` unless it is integration work for existing open PRs.
> > > You can open up new pull requests in the next days and weeks as usual. If
> > > these are documentation enhancements, we will most likely integrate them
> > > quickly. If these are bugfixes, we may still integrate them for PETSc 3.10,
> > > decided on a per-case basis. New features, however, will not be integrated
> > > until PETSc 3.10 is out.
> > > Thanks and best regards,
> > > Karli
> > > > this is a gentle reminder for the cutoff-date on September 4.
> > > > Best regards,
> > > > Karli
> > > >> in order to ensure a PETSc 3.10 release no later than by the end of
> > > >> September (possibly earlier), we agreed on September 4, 2018, as the
> > > >> cut-off date for new features. Please make sure that a pull request has
> > > >> been opened on Bitbucket by this time. This is the preferred model over
> > > >> merging to next directly, since our Jenkins test infrastructure will test
> > > >> each PR separately (thus providing faster feedback and thus allow for
> > > >> faster integration).
> > > >> And while we are at it: Please keep in mind that new features also require
> > > >> appropriate documentation. :-)
> > > >> Karli
