[petsc-dev] PETSc 3.10: September 4, 2018, is the cutoff-date for new features
Tue Sep 11 09:58:38 CDT 2018
Reminder!
please check
http://www.mcs.anl.gov/petsc/documentation/changes/dev.html and update
src/docs/website/documentation/changes/dev.html with relavent changes.
Satish
On Mon, 10 Sep 2018, Satish Balay wrote:
> Also - please check and update src/docs/website/documentation/changes/dev.html as needed.
> Thanks,
> Satish
> On Wed, 5 Sep 2018, Karl Rupp wrote:
> > Dear PETSc developers,
> > please open any outstanding pull requests for the upcoming PETSc 3.10 release
> > in the next few hours. After that, please do not merge anything to `next` or
> > `master` unless it is integration work for existing open PRs.
> > You can open up new pull requests in the next days and weeks as usual. If
> > these are documentation enhancements, we will most likely integrate them
> > quickly. If these are bugfixes, we may still integrate them for PETSc 3.10,
> > decided on a per-case basis. New features, however, will not be integrated
> > until PETSc 3.10 is out.
> > Thanks and best regards,
> > Karli
> > > this is a gentle reminder for the cutoff-date on September 4.
> > > Best regards,
> > > Karli
> > >> in order to ensure a PETSc 3.10 release no later than by the end of
> > >> September (possibly earlier), we agreed on September 4, 2018, as the
> > >> cut-off date for new features. Please make sure that a pull request has
> > >> been opened on Bitbucket by this time. This is the preferred model over
> > >> merging to next directly, since our Jenkins test infrastructure will test
> > >> each PR separately (thus providing faster feedback and thus allow for
> > >> faster integration).
> > >> And while we are at it: Please keep in mind that new features also require
> > >> appropriate documentation. :-)
> > >> Karli
