[petsc-dev] DMPlex example no longer works in complex
    Jose E. Roman
    jroman at dsic.upv.es
    Fri Sep  7 04:42:48 CDT 2018
In SLEPc we have an example (ex34.c, contributed by Fande Kong) that uses DMPlex. In the nightly tests we see a difference that did not ocurr yesterday.
The problem may be caused by the merge of branch tisaac/feature-space-tensor
The difference appears only in complex scalars. To reproduce the problem:
REAL:~/soft/slepc/src/eps/examples/tutorials (master)$ ./ex34 -petscspace_degree 1 -petscspace_poly_tensor
 Solution method: power (nonlinear)
 Number of requested eigenvalues: 1
k: 64.392 error: 6.91725e-07
COMPLEX:~/soft/slepc/src/eps/examples/tutorials (master)$ ./ex34 -petscspace_degree 1 -petscspace_poly_tensor
k: 165.007 error: 199.037
Jose
