[petsc-dev] XDestroy should set Fortran to PETSC_NULL_X
Smith, Barry F.
bsmith at mcs.anl.gov
Thu Sep 6 00:32:12 CDT 2018
I think does the trick: https://bitbucket.org/petsc/petsc/pull-requests/1106/change-fortran-null-pointer-to-match-c/diff
Barry
> On Sep 5, 2018, at 5:55 PM, Jed Brown <jed at jedbrown.org> wrote:
> It is safe in Fortran to write
> call DMDestroy(da, ierr)
> but not
> da = PETSC_NULL_DM
> That's pretty lame and inconsistent with the analogous C concept.
> Should we either change the value of PETSC_NULL_DM or change the
> generated Destroy code?
