[petsc-dev] Compiling PETsc against openblas on Linux
    Matthew Knepley
    knepley at gmail.com
    Sun Sep  2 10:45:30 CDT 2018
On Sun, Sep 2, 2018 at 11:11 AM Antonio <anto.trande at gmail.com> wrote:
>  --with-blas-lapack-lib=-lopenblas --known-64-bit-blas-indices=0
I am curious why you are giving the 64-bit option. This should be figured
automatically unless
you cannot executable programs on the platform on which you are
configuring. What goes wrong?
     Matt
> is working.
> Thanks.
> On 31/08/2018 20:11, Satish Balay wrote:
> > It should work. configure.log will have details..
> > Satish
> > balay at asterix /home/balay/petsc (maint=)
> > $ ./configure --with-blaslapack-lib=-lopenblas
> >              Configuring PETSc to compile on your system
>           It appears you do not have valgrind installed on your system.
>                     We HIGHLY recommend you install it from
> www.valgrind.org
>                                                Or install valgrind-devel or
> equivalent using your package manager.
>                                                         Then rerun
> ./configure
>     Compilers:
> >   C Compiler:         mpicc    -Wall -Wwrite-strings
> -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector
> -fvisibility=hidden -g3
> >   C++ Compiler:       mpicxx  -Wall -Wwrite-strings -Wno-strict-aliasing
> -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g
> >   Fortran Compiler:   mpif90   -Wall -ffree-line-length-0
> -Wno-unused-dummy-argument -g
> > Linkers:
> >   Shared linker:   mpicc  -shared    -Wall -Wwrite-strings
> >   Dynamic linker:   mpicc  -shared    -Wall -Wwrite-strings
> > make:
> > BLAS/LAPACK: -lopenblas
> > MPI:
> > cmake:
> > X:
> >   Library:  -lX11
> > c2html:
> >   Arch:
> > pthread:
> >   Library:  -lpthread
> > PETSc:
> >   PETSC_ARCH: arch-linux2-c-debug
> >   PETSC_DIR: /home/balay/petsc
> >   Scalar type: real
> >   Precision: double
> >   Clanguage: C
> >   Integer size: 32
> >   shared libraries: enabled
> >   Memory alignment: 16
> xxx=========================================================================xxx
> >  Configure stage complete. Now build PETSc libraries with (gnumake
> build):
> >    make PETSC_DIR=/home/balay/petsc PETSC_ARCH=arch-linux2-c-debug all
> > On Fri, 31 Aug 2018, Antonio wrote:
> >> It's failing for missing (not required) links:
> >> Executing: mpicc  -o /tmp/petsc-FYncGY/config.libraries/conftest
> >> -Wl,-z,relro   -fPIC  -Wall -Wwrite-strings -Wno-strict-aliasing
> >> -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g3
> >> /tmp/petsc-FYncGY/config.libraries/conftest.o  -lsunperf -lfui -lfsu
> >> -lsunmath -lm -lstdc++ -ldl -L/usr/lib64/openmpi/lib -lmpi_usempif08
> >> -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lgfortran -lm
> >> -L/usr/lib/gcc/x86_64-redhat-linux/8 -L/usr/lib64/openmpi/lib -lgfortran
> >> -lm -lgcc_s -lquadmath -lpthread -lstdc++ -ldl
> >> Possible ERROR while running linker: exit code 256
> >> stderr:
> >> /usr/bin/ld: cannot find -lsunperf
> >> /usr/bin/ld: cannot find -lfui
> >> /usr/bin/ld: cannot find -lfsu
> >> /usr/bin/ld: cannot find -lsunmath
> >> collect2: error: ld returned 1 exit status
> >>                       Popping language C
> >>                 Unknown name mangling in BLAS/LAPACK
> >>               MKL Path not found.. skipping: /cygdrive/c/Program
> >> Files/Intel/MKL/9.0
> >> Files/Intel/MKL/8.1.1
> >> Files/Intel/MKL/8.1
> >> Files/Intel/MKL/8.0.1
> >> Files/Intel/MKL/8.0
> >> Files/Intel/MKL72
> >> Files/Intel/MKL70
> >> Files/Intel/MKL61
> >> Files/Intel/MKL
> >> **** Configure header /tmp/petsc-FYncGY/confdefs.h ****
> >> On 31/08/2018 19:41, Smith, Barry F. wrote:
> >>>    Ah, sorry for the confusion. We do support --download-openblas
> where PETSc will download and install and OpenBlas for you but if you have
> it already installed then you need to treat it just as a BLASLAPACK library
> so use
> >>>> --with-blaslapack-include=%{_includedir} \
> >>>> --with-blaslapack-lib=%{_libdir}/libopenblas.so \
> >>>> --known-64-bit-blas-indices=0 \
> >>>    If this fails then mail configure.log to petsc-maint at mcs.anl.gov
> >>>     Barry
> Antonio Trande
> Fedora Project
> mailto 'sagitter at fedoraproject dot org'
> GPG key: 0x5E212EE1D35568BE
> GPG key server: https://keys.fedoraproject.org/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180902/d3d5211b/attachment-0001.html>
