[petsc-dev] Compiling PETsc against openblas on Linux
Antonio
anto.trande at gmail.com
Sun Sep 2 10:11:19 CDT 2018
--with-blas-lapack-lib=-lopenblas --known-64-bit-blas-indices=0
is working.
Thanks.
On 31/08/2018 20:11, Satish Balay wrote:
> It should work. configure.log will have details..
> Satish
> balay at asterix /home/balay/petsc (maint=)
> $ ./configure --with-blaslapack-lib=-lopenblas
> Configuring PETSc to compile on your system
> =============================================================================== It appears you do not have valgrind installed on your system. We HIGHLY recommend you install it from www.valgrind.org Or install valgrind-devel or equivalent using your package manager. Then rerun ./configure =============================================================================== Compilers:
> C Compiler: mpicc -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g3
> C++ Compiler: mpicxx -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g
> Fortran Compiler: mpif90 -Wall -ffree-line-length-0 -Wno-unused-dummy-argument -g
> Linkers:
> Shared linker: mpicc -shared -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g3
> Dynamic linker: mpicc -shared -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fstack-protector -fvisibility=hidden -g3
> make:
> BLAS/LAPACK: -lopenblas
> MPI:
> cmake:
> X:
> Library: -lX11
> c2html:
> Arch:
> pthread:
> Library: -lpthread
> PETSc:
> PETSC_ARCH: arch-linux2-c-debug
> PETSC_DIR: /home/balay/petsc
> Scalar type: real
> Precision: double
> Clanguage: C
> Integer size: 32
> shared libraries: enabled
> Memory alignment: 16
> xxx=========================================================================xxx
> Configure stage complete. Now build PETSc libraries with (gnumake build):
> make PETSC_DIR=/home/balay/petsc PETSC_ARCH=arch-linux2-c-debug all
> On Fri, 31 Aug 2018, Antonio wrote:
>> It's failing for missing (not required) links:
>> Executing: mpicc -o /tmp/petsc-FYncGY/config.libraries/conftest
>> -Wl,-z,relro -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing
>> /tmp/petsc-FYncGY/config.libraries/conftest.o -lsunperf -lfui -lfsu
>> -lsunmath -lm -lstdc++ -ldl -L/usr/lib64/openmpi/lib -lmpi_usempif08
>> -lmpi_usempi_ignore_tkr -lmpi_mpifh -lmpi -lgfortran -lm
>> -L/usr/lib/gcc/x86_64-redhat-linux/8 -L/usr/lib64/openmpi/lib -lgfortran
>> -lm -lgcc_s -lquadmath -lpthread -lstdc++ -ldl
>> Possible ERROR while running linker: exit code 256
>> stderr:
>> /usr/bin/ld: cannot find -lsunperf
>> /usr/bin/ld: cannot find -lfui
>> /usr/bin/ld: cannot find -lfsu
>> /usr/bin/ld: cannot find -lsunmath
>> collect2: error: ld returned 1 exit status
>> Popping language C
>> Unknown name mangling in BLAS/LAPACK
>> MKL Path not found.. skipping: /cygdrive/c/Program
>> Files/Intel/MKL/9.0
>> Files/Intel/MKL/8.1.1
>> Files/Intel/MKL/8.1
>> Files/Intel/MKL/8.0.1
>> Files/Intel/MKL/8.0
>> Files/Intel/MKL72
>> Files/Intel/MKL70
>> Files/Intel/MKL61
>> Files/Intel/MKL
>> **** Configure header /tmp/petsc-FYncGY/confdefs.h ****
>> On 31/08/2018 19:41, Smith, Barry F. wrote:
>>> Ah, sorry for the confusion. We do support --download-openblas where PETSc will download and install and OpenBlas for you but if you have it already installed then you need to treat it just as a BLASLAPACK library so use
>>>> --with-blaslapack-include=%{_includedir} \
>>>> --with-blaslapack-lib=%{_libdir}/libopenblas.so \
>>>> --known-64-bit-blas-indices=0 \
>>> If this fails then mail configure.log to petsc-maint at mcs.anl.gov
>>> Barry
Antonio Trande
Fedora Project
mailto 'sagitter at fedoraproject dot org'
GPG key: 0x5E212EE1D35568BE
GPG key server: https://keys.fedoraproject.org/
