[petsc-dev] Plex - Metis warnings
    Mark Adams
    mfadams at lbl.gov
    Mon Oct 29 19:07:04 CDT 2018
I was able to run ksp ex56 manually. This machine requires an inscrutable
workflow. I built the code in my home directory, copied the executable to a
working directory and ran there. I have seen my colleagues do this copy
business that is clearly not in PETSc tests. I don't understand it but I
can I can hand if off to my users with some assurance that it _can_ work!
On Mon, Oct 29, 2018 at 7:23 PM Balay, Satish <balay at mcs.anl.gov> wrote:
> On Mon, 29 Oct 2018, Mark Adams via petsc-dev wrote:
> > >                             Pushing language C
> > >                             Popping language C
> > > Executing: cc  -o /tmp/petsc-yiGfSd/config.packages.MPI/conftest     -O
> > > /tmp/petsc-yiGfSd/config.packages.MPI/conftest.o  -ldl
> > > Testing executable /tmp/petsc-yiGfSd/config.packages.MPI/conftest to
> see
> > > if it can be run
> > > Executing: /tmp/petsc-yiGfSd/config.packages.MPI/conftest
> > > ERROR while running executable: Could not execute
> > > "['/tmp/petsc-yiGfSd/config.packages.MPI/conftest']":
> > > [Mon Oct 29 17:44:45 2018] [unknown] Fatal error in MPI_Init: Other MPI
> > > error, error stack:
> > > MPIR_Init_thread(537):
> > > MPID_Init(249).......: channel initialization failed
> > > MPID_Init(638).......:  PMI2 init failed: 1
> > > So all MPI tests fail on frontend? And you need to use --with-batch?
> > I ran the tests from an interactive shell. I guess I should run configure
> > from an interactive shell. but configure and make seemed to work.
> Executing: aprun /tmp/petsc-yiGfSd/config.libraries/conftest
> stdout: XALT Error: unable to find aprun
> ERROR while running executable: Could not execute "['aprun
> /tmp/petsc-yiGfSd/config.libraries/conftest']":
> Are you able to use 'aprun' via interactive nodes to run MPI jobs? Somehow
> configure is unable to use aprun.
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181029/d9f2f894/attachment-0001.html>
