[petsc-dev] Plex - Metis warnings
    Mark Adams
    mfadams at lbl.gov
    Mon Oct 29 17:33:38 CDT 2018
>                             Pushing language C
>                             Popping language C
> Executing: cc  -o /tmp/petsc-yiGfSd/config.packages.MPI/conftest     -O
> /tmp/petsc-yiGfSd/config.packages.MPI/conftest.o  -ldl
> Testing executable /tmp/petsc-yiGfSd/config.packages.MPI/conftest to see
> if it can be run
> Executing: /tmp/petsc-yiGfSd/config.packages.MPI/conftest
> ERROR while running executable: Could not execute
> "['/tmp/petsc-yiGfSd/config.packages.MPI/conftest']":
> [Mon Oct 29 17:44:45 2018] [unknown] Fatal error in MPI_Init: Other MPI
> error, error stack:
> MPIR_Init_thread(537):
> MPID_Init(249).......: channel initialization failed
> MPID_Init(638).......:  PMI2 init failed: 1
> So all MPI tests fail on frontend? And you need to use --with-batch?
I ran the tests from an interactive shell. I guess I should run configure
from an interactive shell. but configure and make seemed to work.
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181029/2137e01d/attachment-0001.html>
