[petsc-dev] I just removed Fortran support from my development build
Mon Oct 22 10:27:41 CDT 2018
On Mon, Oct 22, 2018 at 10:58 AM Dener, Alp <adener at anl.gov> wrote:
> On Oct 22, 2018, at 8:18 AM, Matthew Knepley <knepley at gmail.com> wrote:
> Jenkins will now catch bad Fortran bindings. However, this is a larger
> problem. GFortran takes forever to build the bindings. Is it similar for
> other compilers?
> On my MacBook, the Homebrew GFortran 8.2.0 takes 5-8 seconds on `make
> allfortranstubs`, and ~30 seconds on Fortran modules during `make`. The
> full compile finishes in about 3.5 minutes total. Doesn’t seem like a very
> long time to me, but then again I also have a very barebones configuration
> with only MPI and blas/lapack.
1) You have to compare the modules to the rest of the build, since I am
rebuilding very frequently.
2) I am on the Mac Air, so it takes longer.
   Matt
>   Matt
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181022/17781942/attachment.html>
