[petsc-dev] MUMPS silent errors
Matthew Knepley
knepley at gmail.com
Wed Oct 10 14:53:08 CDT 2018
On Wed, Oct 10, 2018 at 3:12 PM Zhang, Junchao <jczhang at mcs.anl.gov> wrote:
> I met a case where MUMPS numeric factorization returned an error code -9 in mumps->id.INFOG(1) but A->erroriffailure was false in the following code in mumps.c
> 1199: *PetscErrorCode <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscErrorCode.html#PetscErrorCode> MatFactorNumeric_MUMPS(Mat <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat> F,Mat <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat> A,const MatFactorInfo <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatFactorInfo.html#MatFactorInfo> *info)*
> 1200: {
> ...1227: PetscMUMPS_c(mumps);1228: if (mumps->id.INFOG(1) < 0) {1229: if (A->erroriffailure) {1230: SETERRQ2 <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/SETERRQ2.html#SETERRQ2>(PETSC_COMM_SELF <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PETSC_COMM_SELF.html#PETSC_COMM_SELF>,PETSC_ERR_LIB,"Error reported by MUMPS in numerical factorization phase: INFOG(1)=%d, INFO(2)=%d\n",mumps->id.INFOG(1),mumps->id.INFO(2));1231: } else {1232: if (mumps->id.INFOG(1) == -10) { /* numerically singular matrix */1233: PetscInfo2(F,"matrix is numerically singular, INFOG(1)=%d, INFO(2)=%d\n",mumps->id.INFOG(1),mumps->id.INFO(2));1234: F->factorerrortype = MAT_FACTOR_NUMERIC_ZEROPIVOT;
> The code continued to KSPSolve and finished successfully (with wrong answer). The user did not call KSPGetConvergedReason() after KSPSolve. I found I had to either add -ksp_error_if_not_converged or call KSPSetErrorIfNotConverged(ksp,PETSC_TRUE) to make the code fail.
> Is it expected? In my view, it is dangerous. If MUMPS fails in one stage, PETSc should not proceed to the next stage because it may hang there.
> We made the executive decision to have solves complete by default. This is
consistent with that decision. Users who want safety can ask for the error.
It would be nice of MUMPS would cleanup correctly, but we can report that
to them as a bug.
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181010/fea1032f/attachment.html>
