[petsc-dev] MUMPS silent errors
Zhang, Junchao jczhang at mcs.anl.gov
Wed Oct 10 14:12:37 CDT 2018
I met a case where MUMPS numeric factorization returned an error code -9 in mumps->id.INFOG(1) but A->erroriffailure was false in the following code in mumps.c
1199: PetscErrorCode<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PetscErrorCode.html#PetscErrorCode> MatFactorNumeric_MUMPS(Mat<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat> F,Mat<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/Mat.html#Mat> A,const MatFactorInfo<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatFactorInfo.html#MatFactorInfo> *info)
1200: {
1227:   PetscMUMPS_c(mumps);
1228:   if (mumps->id.INFOG(1) < 0) {
1229:     if (A->erroriffailure) {
1230:       SETERRQ2<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/SETERRQ2.html#SETERRQ2>(PETSC_COMM_SELF<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Sys/PETSC_COMM_SELF.html#PETSC_COMM_SELF>,PETSC_ERR_LIB,"Error reported by MUMPS in numerical factorization phase: INFOG(1)=%d, INFO(2)=%d\n",mumps->id.INFOG(1),mumps->id.INFO(2));
1231:     } else {
1232:       if (mumps->id.INFOG(1) == -10) { /* numerically singular matrix */
1233:         PetscInfo2(F,"matrix is numerically singular, INFOG(1)=%d, INFO(2)=%d\n",mumps->id.INFOG(1),mumps->id.INFO(2));
1234:         F->factorerrortype = MAT_FACTOR_NUMERIC_ZEROPIVOT;
The code continued to KSPSolve and finished successfully (with wrong answer). The user did not call KSPGetConvergedReason() after KSPSolve. I found I had  to either add -ksp_error_if_not_converged or call KSPSetErrorIfNotConverged(ksp,PETSC_TRUE) to make the code fail.
Is it expected?  In my view, it is dangerous. If MUMPS fails in one stage, PETSc should not proceed to the next stage because it may hang there.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181010/c881d01b/attachment.html>
