[petsc-dev] No LocalToGlobalMapping in DMPlex
    Matthew Knepley
    knepley at gmail.com
    Sun Oct  7 22:54:19 CDT 2018
On Fri, Oct 5, 2018 at 2:58 PM Tristan Konolige <
Tristan.Konolige at colorado.edu> wrote:
> Hello PETSc Developers,
> I’d like to get an ISLocalToGlobalMapping from a DMPlex. But,
> currently, DMGetLocalToGlobalMapping returns an empty
> ISLocalToGlobalMapping. I can see that ISLocalToGlobalMappings are created
> in DMPlexDistribute, but they are never assigned to the DM. Is
> DMGetLocalToGlobalMapping supported with DMPlex or is this a bug?
LocalToGlobal mappings are only meaningful for function spaces, not
topology. DMPlex itself only deals with topology. You have to give it a
PetscSection if you want to say something about the function space, using
DMSetSection().
DMDA only has one function space (values at vertices), so it just uses this
by default, and GetLocalToGlobal() works automatically.
    Matt
> I’ve included a simple example below.
> #include <petsc.h>
> int main(int argc, char** argv) {
>   PetscErrorCode ierr;
>   PetscInt size;
>   ISLocalToGlobalMapping l2g;
>   DM dm, dm_dist;
>   PetscInt num_points[2] = {2, 2};
>   PetscInt cone_size[4] = {1, 1, 0, 0};
>   PetscInt cones[2] = {2,3};
>   PetscInt orientations[2] = {0, 0};
>   PetscInt local_points[2] = {0, 1};
>   PetscInt global_points[2];
>   PetscInitialize(&argc, &argv, NULL, NULL);
>   DMPlexCreate(PETSC_COMM_WORLD, &dm);
>   DMPlexCreateFromDAG(dm, 1, num_points, cone_size, cones, orientations,
> NULL);
>   DMPlexDistribute(dm, 0, NULL, &dm_dist);
>   DMGetLocalToGlobalMapping(dm_dist, &l2g);
>   ISLocalToGlobalMappingApply(l2g, 2, local_points, global_points);
>   PetscFinalize();
> Thank you,
> Tristan Konolige
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181007/0a239d81/attachment.html>
