[petsc-dev] No LocalToGlobalMapping in DMPlex
Tristan Konolige
Tristan.Konolige at Colorado.EDU
Fri Oct 5 13:58:48 CDT 2018
Hello PETSc Developers,
I’d like to get an ISLocalToGlobalMapping from a DMPlex. But, currently, DMGetLocalToGlobalMapping returns an empty ISLocalToGlobalMapping. I can see that ISLocalToGlobalMappings are created in DMPlexDistribute, but they are never assigned to the DM. Is DMGetLocalToGlobalMapping supported with DMPlex or is this a bug?
I’ve included a simple example below.
#include <petsc.h>
int main(int argc, char** argv) {
PetscErrorCode ierr;
PetscInt size;
ISLocalToGlobalMapping l2g;
DM dm, dm_dist;
PetscInt num_points[2] = {2, 2};
PetscInt cone_size[4] = {1, 1, 0, 0};
PetscInt cones[2] = {2,3};
PetscInt orientations[2] = {0, 0};
PetscInt local_points[2] = {0, 1};
PetscInt global_points[2];
PetscInitialize(&argc, &argv, NULL, NULL);
DMPlexCreate(PETSC_COMM_WORLD, &dm);
DMPlexCreateFromDAG(dm, 1, num_points, cone_size, cones, orientations, NULL);
DMPlexDistribute(dm, 0, NULL, &dm_dist);
DMGetLocalToGlobalMapping(dm_dist, &l2g);
ISLocalToGlobalMappingApply(l2g, 2, local_points, global_points);
PetscFinalize();
Thank you,
Tristan Konolige
