[petsc-dev] configure issues with new MKL and --with-mkl_sparse_optimize=0
Stefano Zampini
stefano.zampini at gmail.com
Thu Nov 29 03:09:18 CST 2018
No specific reasons. I have just used config/examples/arch-pardiso.py
(which has --with-mkl_sparse_optimize=0) with a relatively recent MKL
distribution
Il giorno mar 27 nov 2018 alle ore 03:22 Mills, Richard Tran <
rtmills at anl.gov> ha scritto:
> Oh, I should also have asked: Why are you telling PETSc to not use
> mkl_sparse_optimize()? Does it cause some sort of problem if you build with
> that on?
> --Richard
> On 11/21/18 10:59 PM, Stefano Zampini wrote:
> Richard,
> I just noticed that PETSc master does not build with the options
> '--with-mkl_pardiso-dir=/soft/com/packages/intel/18/u3/mkl',
> '--with-mkl_sparse_optimize=0',
> This is on frog at MCS, but it will be the same on other machines as the
> macros configuration
> PETSC_HAVE_MKL_SPARSE_OPTIMIZE not defined
> PETSC_HAVE_MKL_SPARSE_SP2M defined
> does not seem to be supported.
> /nfs2/szampini/src/petsc/src/mat/impls/aij/seq/aijmkl/aijmkl.c(797):
> error: struct "<unnamed>" has no field "csrA"
> csrA = a->csrA;
> Could you please take a look? Why is the mkl_sparse_sp2m package flagged
> as lookforbydefault in the configure scripts?
> Thanks
> Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20181129/fbb43279/attachment.html>
